Voice translation rule - BLOCK number with +
ziqex
Level 4
Level 4
I want to use voice translation-rule to reject specific number.
This number has format starting with +4917
If I attempt to add it like below:
rule 3 reject /^+4917XYZ/ it is not being accepted
Same with rule
3 reject /+4917XYZ/ it is not being accepted either
Please advise
@ziqex,
The backslash is an escape character in regular expressions, so in order to match a literal plus sign (+), you need to escape it with another backslash. So, the correct syntax to match a string that starts with "+4917" using a regular expression in a Cisco voice translation-rule would be:
rule 3 reject /^\+4917/
Note that the first backslash escapes the second backslash, which in turn escapes the plus sign.
Best regards
M02@rt37
Hello @ziqex,
In your case, you can use the following command to reject the number starting with +4917:
Best regards
Is there any difference between rule 3 reject /^\+4917/ and rule 3 reject /^\\+4917/?
@ziqex,
Best regards
You need to escape special characters, like a plus, in the match part of the rule. To do that add a \ in-front of the character, ie \+.
Response Signature
