Voice Translation Rule for a Blocked/Private Calling ID Number
Peter Valdes
Level 3
Level 3
Calling ID = Anonymous
Called ID = 02 XXXX 2228
CUCM is setup with Translation Pattern of 2228 which redirects to International Number.
When I call 2228 internal same CUCM cluster, the redirection works. When I call from outside but showing my Calling ID, its works. But when I hide my Calling ID to blocked or private and calling from outside the network, the redirection does not work.
Call Flow = SP1 -> SIP Trunk -> CUBE -> CUCM -> Trans Patter 2228 redirects Internation Number -> CUBE -> SIP Trunk -> SP1
CUCM SIP Trunk is setup with outbound calls Calling Party Selection = Last Redirect Number (external)
Our SIP ISP requires a number within the business to be presented as the Calling Party.
I need assistant with setting up a Voice Translation Rule on the CUBE to fix the Calling ID private.
Peter
TONY SMITH
Can you take some SIP debugs "debug ccsip mess" and post up the two Invites - the inbound one received from CUCM, and the outbound one to the ITSP?   It might be that a SIP profile is needed instead of, or as well as a voice translation rule.
