06-03-2011 08:55 AM - edited 03-16-2019 05:17 AM
I have a voice translation rule:
voice translation-rule 1
rule 1 /\(.*\)/ /xxx/ (where xxx is the ext that all incoming calls are going to)
And this works fine. Question is, can I add another extension so that all incoming calls call 2 extensions?
Paul
Solved! Go to Solution.
06-03-2011 09:10 AM
No, you can not.
What you want is called shared line and is done configuring the same DN on multiple telephones.
06-03-2011 09:10 AM
No, you can not.
06-06-2011 01:48 AM
Thanks Paolo.
