Voice Translation rule
Paul Monteith
Beginner
Beginner
I have a voice translation rule:
voice translation-rule 1
rule 1 /\(.*\)/ /xxx/ (where xxx is the ext that all incoming calls are going to)
And this works fine.  Question is, can I add another extension so that all incoming calls call 2 extensions?
Paul
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
No, you can not.
What you want is called shared line and is done configuring the same DN on multiple telephones.
paolo bevilacqua
Hall of Fame Master
No, you can not.
Thanks Paolo.
Recognize Your Peers
