11-25-2019 05:32 PM
Hi All,
I am trying to understand the voice translation rules and have got confused with complex usage of it. Below are some patterns :
/.*\(...\)$/ /8\1/ ---- My understanding - This means any number being dialed is prefixed by 8 followed by the 3 digits that form set 1
/^8\(...\)$/ /0290838\1/ --- My understanding - This means any number starting with 8 and followed by any 3 digits gets replaced by 0290838 followed by the 3 digits that form set 1
/.+/ /00011\0/ type international international ---- In this i am unable to understand the variable "TYPE" - how is the number identified as international here for the rule match to happen ?
11-25-2019 11:20 PM
The 2 following links may be useful for you:
https://ucpros.net/cisco-voice-translation-rules-guide/
G
11-26-2019 12:09 AM
"/.+/ /00011\0/ type international international ---- In this i am unable to understand the variable "TYPE" - how is the number identified as international here for the rule match to happen ? "
Number type is a specific property in ISDN and H.323 signalling, maybe others. For example in ISDN ..
Nov 26 08:06:55.724: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x7C9E Sending Complete Bearer Capability i = 0x8090A3 Standard = CCITT Transfer Capability = Speech Transfer Mode = Circuit Transfer Rate = 64 kbit/s Channel ID i = 0xA98381 Exclusive, Channel 1 Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-band info Calling Party Number i = 0x1181, 'xxxxxxxxxxxx' Plan:ISDN, Type:International Called Party Number i = 0x81, '3499' Plan:ISDN, Type:Unknown
Note that SIP doesn't have this field, so as far as I know you can't match based on explicit type, you have to deduce it from the number actually presented.
11-26-2019 09:39 AM - edited 11-26-2019 10:51 AM
Your understanding is correct. Another way to say it: Strip off all but the last three digits of the number, and then prefix those 3 digits with an 8. E.g., 6125551212 becomes 8212
Your understanding is correct. There's not better way to say it! :)
So the type keyword is going to look at the signaling messages, to determine if the Type of Number (aka TON) can be determined. If so, then it would have to be equal to International for a match to be made, regardless of what the pattern before is trying to match on. Think of it like an AND operator. The pattern must match .+ (which means at least 1 digit, but could be more) AND the TON must match international.
Tony already pointed out where the TON comes from, and that it's not used in SIP. +5 for him.
Now, the word in international is in their twice, because just like pattern matching it is doing a find and replace. Find international and replace with international. This effectively changes nothing about the TON, but makes sure the match only happens on TON international and not TON National or TON Subscriber or TON Unknown. The \0 which we haven't seen in your other two examples, does the same thing as \1, but contains all of the digits matched by .+ (so, literally all of the digits). Whereas a \1 only contains the digits matched between the parenthesis. Two ways to achieve the same thing really. Because you could have used /\(.+\)/ /00011\1/ instead.
Chris George already linked you to some resources, one of which shows you how to test your rules on the router, so +5 for him too.
11-26-2019 10:35 AM
And 5 Stars to Anthony who always finds ways to explain everything so well, that everything sounds so easy.
George
11-26-2019 10:53 AM
