voice translation
abd88elhak
hi
i'm using voice gateway H323 with E1
i would like to translate any number by this 520488731 using voice translation-rule
how can i do it
regards
Jaime Valencia
There's plenty of documentation around the topic on cisco.com, and it contains plenty of examples for how to use them, have you reviewed them????
java
if this helps, please rate
