Voice translations help
I am trying to setup a simple voice translation to dial 9 out....
We dial our numbers as: 9+1+xxx+xxx+xxxx
We need 9 stripped so that way1XXXXXXXXXX is pushed to our SIP trunk.
I tried a few ways and it goes busy.
Also what is the destination pattern supposed to be in conjunction with this?
7 Replies 7
Dennis Mink
Advisor
Advisor
I dont think you need a translation pattern,  If you want to route 91XXXXXXXXX   just add a route pattern on CUCM 9.1XXXXXXXXX  and discard digits predot and point that to your TRunk as you would with any Route pattern.
(assuming you are doing this on a CUCM)
Please remember to rate useful posts, by clicking on the stars below.
Anas Abueideh
Engager
Engager
if you want just to remove the 9 you can apply the following config
voice translation-rule 1
  rule 1 /^9\(.*\)/ /\1/
voice translation-profile discard9
  translate called 1
at the outbound dial-peer you need to assign the translation profile
dial-peer voice 100 voip
destination-pattern 91.........
translation-profile outgoing discard9
Anas
please don't forget to rate the helpful posts
So can you explain why its called not calling?
I have attached my config, for better way to associate any changes...
What we would like to do is setup:
Dial 9 to get out and the remaining digits for local
Dial 9 to get out, with 1 for national calls
911 calling
411 calling
Could you assist in giving us a config for us to use?
Hi Frederick,
we the translation profile for the called because we need to manipulate the called number and remove 9.
for 911 calls you don't need to apply the translation profile.
you need to create dial-peers for the different route patterns.
for calling number you need to create translation-profile to change the calling number to your company DID
Anas
your config should be like the following
rule 1 /7347947685/ /1000/
voice translation-rule 2
  rule 1 /^9\(.*\)/ /1/
voice translation-rule 3
   rule 1 // /7347947685/
voice translation-profile IN_TO_1000
translate called 1
voice translation-profile SIP_OUTBOUND
translate called 2
translate calling 3
dial-peer voice 2000 voip
description **VoIP MS OUTBOUND**
translation-profile outgoing SIP_OUTBOUND
destination-pattern 900T
session protocol sipv2
session target sip-server
session transport udp
voice-class sip asserted-id ppi
no voice-class sip block 180
no voice-class sip block 183
no voice-class sip block 181
voice-class sip pass-thru headers unsupp
voice-class sip pass-thru content unsupp
voice-class sip pass-thru content sdp
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2001 voip
destination-pattern 911
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2002 voip
destination-pattern 411
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2004 voip
destination-pattern 91.......$
dtmf-relay rtp-nte
codec g711ulaw
no vad
destination-pattern 9.......$
dtmf-relay rtp-nte
codec g711ulaw
no vad
Anas
Got it working thanks!   Now if I can only get MWI working with exchange, any ideas?
what is your MWI issue with exchange ?
Anas
Recognize Your Peers
