04-05-2013 08:24 AM - edited 03-16-2019 04:38 PM
Hello all,
I recently took over a cisco network that is using an old NBX v3000 phone system with 3 com voip phones. They just purchased another NBX for our other site (we have a direct connection between the sites). The last network admin was able to get the first NBX phone system set working using the voice vlan connection.
The current system uses vlan 15 for voice and a port set up like this works fine:
switchport access vlan 13
switchport mode access
switchport nonegotiate
switchport voice vlan 15
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust cos
auto qos trust
spanning-tree portfast
I have a phone hooked to the port, it boots, hits the nbx on vlan 15 and downloards an image and gets an extension.
For the new system I set up Vlan 116 to be its voice vlan.
If I change the config:
switchport voice vlan 116
priority-queue out
mls qos trust cos
auto qos trust
The phone boots but just sets there waiting "waiting for NCP"
Anywhere on either site, if I use voice vlan 15 the phone will connect, but if I use 116 it will not.
Both vlans 15, and 116 are set up the same way one the same switch. they both have an ip address, 10.15.1.1 255.255.0.0 and 10.116.1.1 255.255.0.0. Both vlans are trunked, and I can ping their address from other switches across both sites. Neither vlan has an access list applied to it.
Both NBX's are configured with IPs (10.15.1.190 and 10.116.1.190), and vlan tagging.
One thing I have noticed, if I issue the "show mac address-table interface" command to a port using the voice vlan 15 the phones mac is on vlan 15. If I issue the same command with the voice vlan set to 116 the phones mac will be on the access vlan. If I remove the access vlan and only include the voice vlan 116 the mac will show up on Vlan 1...
I feel like the issue is with my vlan 116, though after looking through config after config I cant see a difference between my set up and the last network admin's set up.
Does anyone have any ideas of any other config options that I may need to get this working?
Thanks at ton!
04-05-2013 09:06 AM
What about you dhcp pool? Can you post the full switch and router config?
Yosh
04-05-2013 09:44 AM
kindly post the below command output from switch on that port where vlan 116 is assigned
show interfaces
show running-config interface
04-05-2013 10:04 AM
GigabitEthernet1/0/22 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 000e.3885.da96 (bia 000e.3885.da96)
Description: Port E4 - D117
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 3d22h, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 4000 bits/sec, 5 packets/sec
1282916 packets input, 170417156 bytes, 0 no buffer
Received 24165 broadcasts (13551 multicasts)
0 watchdog, 13551 multicast, 0 pause input
2713213 packets output, 2844013678 bytes, 0 underruns
0 output errors, 0 collisions, 17 interface resets
interface GigabitEthernet1/0/22
description Port E4 - D117
end
There are the show commands, as I said, if I change the 116 to 15 the phone connects to the vlan 15 nbx right away.
we are not using DHCP for the phones, they connect back to the NBX with their mac address.
04-05-2013 10:06 AM
post these command output bro
show interfaces
04-05-2013 10:20 AM
These are she show commands using vlan 15
Dcore#sh int gi1/0/22
5 minute output rate 7000 bits/sec, 6 packets/sec
1283527 packets input, 170803954 bytes, 0 no buffer
Received 24383 broadcasts (13551 multicasts)
end
04-05-2013 10:26 AM
run this command
Dcore#sh int gi1/0/22 switchport
and
Dcore#sh running-config int gi1/0/22
04-05-2013 10:28 AM
Sorry, I missed the switchport on the end of sh interface
Switchport: Enabled
Administrative Mode: static access
Operational Mode: static access
Administrative Trunking Encapsulation: negotiate
Operational Trunking Encapsulation: native
Negotiation of Trunking: Off
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: 116 (VLAN0116)
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Building configuration...
Current configuration : 142 bytes
end
04-05-2013 10:35 AM
everything is in order.
just one more command
Dcore#sh spanning-tree int gi1/0/22
04-05-2013 10:37 AM
Vlan Role Sts Cost Prio.Nbr Type
VLAN0001 Desg FWD 19 128.22 P2p Edge
VLAN0116 Desg FWD 19 128.22 P2p Edge
Dcore#
04-05-2013 10:43 AM
got the issue run below command on that switch port and it will work.
Dcore#config t
Dcore(config)#int gi1/0/22
Dcore(config-if)#switchport mode access
Dcore(config-if)#switchport access vlan 13
Dcore(config-if)#switchport trunk native vlan 13
Dcore(config-if)#switchport trunk allowed vlan 13,116
Do this & check now
04-05-2013 11:03 AM
Switchport: Enabled
Access Mode VLAN: 13 (VLAN0013)
Trunking Native Mode VLAN: 13 (VLAN0013)
Trunking VLANs Enabled: 13,116
Protected: false
VLAN0013 Desg FWD 19 128.22 P2p Edge
end
This is the current config using the commands you suggested. Still no connection. There has to be something with Vlan 116 that is keeping the tagged vlan data from making it to the nbx.
I can ping from the swith to the NBX
Dcore#ping 10.116.1.190
Sending 5, 100-byte ICMP Echos to 10.116.1.190, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/5/9 ms
Dcore#
04-05-2013 11:08 AM
can you post full topology snapshot along with full config of devices?
04-05-2013 11:47 AM
Hi Donald.
On the interface G1/0/22
put this command
switchport mode trunk
switchport trunk allowed vlan 116
Hope this helps
Carlo
