11-20-2019 11:26 PM
Hello
I have 3 IP Phones systems
1- NEC
2- CUCM1
3- CUCM2
the sip trunk is done like that
NEC--->CUCM1--->CUCM2
NEC can call extensions in CUCM1
CUCM1 can call extensions in CUCM2 and NEC
CUCM2 can call extensions in CUCM1 anc NEC
NEC to CUCM1 with dail-pattern 5.XXX
CUCM1 to CUCM2 with dail-pattern 10.XXX
CUCM2 to CUCM1 with dail-pattern 13.XXX
CUCM1 to NEC with dial-pattern 6.XXX
we can't change anything in NEC since IT has no experience
I tried a work around that NEC calls the autoattendant CTI route point 4001 and when they ask them to call the extension which should be in CUCM2 the voice mail says we can't transfer to that number
Solved! Go to Solution.
11-25-2019 12:40 AM
11-25-2019 01:26 AM
i solved the problem in the CUC>Restriction Tables
Thanks for your effort
11-25-2019 12:40 AM
11-25-2019 01:26 AM
