ā03-25-2013 12:52 AM - edited ā03-16-2019 04:25 PM
Good Morning,
I've a problem with voicemail activation.
I've a Cisco Callmanager 8.6.2 and CUe express 8.6.4.
I've configured the CUE with the following parameters:
ccn subsystem jtapi
ctiport 4101 4102
mwiport 1999
ccm-manager address 172.16.41.240
ccm-manager credentials hidden "A2cB9mqLjwehMeqs1KYZPaRdosjZqnxAjmyLyTHrsTtJ3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
end subsystem
ccn trigger jtapi phonenumber 570
application "voicemail"
enabled
maxsessions 1
end trigger
voicemail default language it_IT
voicemail broadcast recording time 300
voicemail default messagesize 240
voicemail notification restriction msg-notification
voicemail mailbox owner "gianca" size 7200
end mailbox
At following on the CUCM I've configured two cti port (4101 and 4102), one CTI route-pont (570) and one application used (jtapiadmin).
I've associated the cti ports and the cti toute point to this user.
And then I've created the voice mail pilot and the voice mail profile.
I've also associate the voicemail porfile to the user.
Either CTI ports and CTI route point are correctly registerd.
Now when I press the voicemail key on the phone, the numer are always busy.
Can you halp me to solve this problem?
Thanks in advance regards
Giancarlo
Solved! Go to Solution.
ā03-26-2013 07:38 AM
Ok.
Now you are receiving a call connect fail 107 which usually means codec mismatch or ,more in general, resource unavailable.
CallCtlConnFailed, Inbound call, callctl cause:107.
Please check pilot and cti ports configuration or try to reset them.
Carlo
ā03-26-2013 07:44 AM
I check the tiu config and I've restard they. but the problem itt's alrewady present.
How I can verficy if the codecs are correct?
ā03-26-2013 07:52 AM
Check in cucm if you are using G.711 codec within your region and, if you ar using different region/device pool for ip phones and cti port / Route Point, make sure that G.711 is the codec used between them.
Carlo
ā03-26-2013 07:54 AM
Hi Carlo in region I use G711 and G722 codec.
I must to disable the g722?
ā03-26-2013 08:33 AM
Hi Giancarlo.
Can you post the CUE config?
Thx
Carlo
ā03-26-2013 08:38 AM
Hi Carlo,
I'was disperate and for that I've deleted and reconfigured all cti port and route point.. and now.... all works!!!
I'don't know why because I've copied the old configuration!!!!!
Thanks for Help .
I'm triyng to rate your help!!!
the CTI ports, CTI route points and phones should be assigned to the same device pool
also make sure that codec in the same region using g711ulaw
Anas
please don't forget to rate the helpful posts
ā03-26-2013 07:59 AM
All CTI port and CTI route point are in the same Device pool.
and the codec itraregion are g722,g711.
ā03-26-2013 06:40 AM
is it working ?
Anas
