09-20-2011 09:46 AM - edited 03-16-2019 07:05 AM
Where is the setting to change where your voicemails go to? Some people have their voicemails going to the Phone, their email or even both. Mine randomly changed from my phone to my email over night and I want it back to the way it was, but I do not know where the setting is to change this. I tried Cisco Unity and Call Manager. I even tried the physical phone itself.
Any help would be greatly appreciated!
Thank you
Solved! Go to Solution.
10-13-2011 04:52 PM
Anilla,
Thanks for the update.
So the unity says the mwi lamp is on - but it is not lit on the phone.
Does the VMAIL DN number from the subscriber page = the IP phone DN
Can you dial the mwi-on number from the phone- does the lamp light ?
Dial the mwi-off number to turn it off.
Alex
10-20-2011 06:12 AM
Anilla
List out the MWI numbers as you did before vooicemail--> message waiting
Click on the MWI ON number, then in the CSS dropdown pick the CSS and save
Repeat for the MWI off
Then TEST
If still failing revert the CSS back to NONE on both the MWI numbers
Alex
09-20-2011 09:48 AM
What voicemail system (Unity, Unity Connection, Untiy Express) and what version are you running?
09-20-2011 12:22 PM
Unity 7.0 Build 7.0(2).
09-26-2011 05:09 AM
I'm still on this issue if anyone has any ideas?
09-26-2011 09:02 AM
In your Unity 7 server integrated with your corporate Exchange or Domino, or is it installed in VMO mode with Exchange on-box?
09-27-2011 05:21 AM
Integrated with Exchange.
10-04-2011 05:59 AM
Anyone?
10-04-2011 06:47 AM
Anilla,
We're going to need more information from you to determine what the issue is. With Unity, voicemails always go to email because it relies on either Exchange or Domino as a backend message storage. From an end user perspective, "where" they see the message is largely dependent upon how it is integrated and associated with an email account. You can have Unity setup in a voicemail only configuration. It still uses Exchange for message storage; however, the user and email account it is associated with a voicemail account on the backend is not the same user/email account that a user knows about. In this manner, voicemail is generally retrieved primarily from the phone so it is referred to as voicemail only.
You can also have Unity integrated with a corporate Exchange backend message store. This is generally a Unified Messaging configuration because the end user/email account that is associated with voicemail is a user's standard user/email account. In this manner, voicemail can be retrieved directly from the Outlook Inbox and/or the phone.
There are other ways to access voicemail in either configuration that may or may not involve the use of email from the end user perspective. However, none of these things are settings that can randomly change or just happen on their own without some configuration. So, if you can give a more detailed description of the issue then maybe we can help you out more.
Hailey
Please rate helpful posts!
10-05-2011 07:55 AM
Okay, so this is what is happening. The Vice President of the company put in a Help Desk that the MWI on his phone was not coming on when he got a voicemail. He has a Series 7940 Cisco IP Phone. After inspection, I noticed he had internal calls being forwarded to his cell phone, so those voicemails were being stored there, not a problem; he was okay with that. His problem is when external callers leave a voicemail, he has to login and check his mail or look at his Blackberry. He is in and out of the office a lot and would like to be able to walk by his desk, see whether the light is on or not and proceed from that point. I know the light not coming on is because he has voicemails going to his email and I just need that to go to his phone instead.
Thank you for your help thus far! It is much appreciated!
10-12-2011 06:59 AM
Anyone?
10-12-2011 09:18 AM
Anilla,
Try looking at the subscriber on the unity
Click on the MESSAGES setting in the left
What does the MWI extension setting have under the Extension number
By default it should just have an "X" this means it should light his own extension DN on his ip-phone
Alex
10-13-2011 10:25 AM
Alex,
There is an X there, Send Counts isn't checked, but it says the indicator lamps is on.
Thanks!
10-13-2011 04:52 PM
Anilla,
Alex
10-18-2011 08:15 AM
Alex,
Not sure why it chose your answer as the right one, considering the issue is not yet resolved. None the less. the Voicemail DN is the same for both the Subscriber Page and the IP Phone. Not exactly sure what you meant at this point
"Can you dial the mwi-on number from the phone- does the lamp light ?
Dial the mwi-off number to turn it off."
I was unaware that this could be done, could you please elaborate?
Thank you
10-19-2011 06:22 AM
Anilla,
Sorry for the delay.
The MWI -ON & OFF numbers are part of the integration setup between CUCM & Unity.
From the UNITY Admin web page you should be able to look at :-
SYSTEM ---> INTEGRATION
Look at the page for your CUCM integration and you will see the MWI Numbers.
You should be able to dial these from your phones to test the lamps (LEDS)
Alex
