05-13-2013 09:09 AM - edited 03-16-2019 05:17 PM
Gents,
Any idea why the voicemail stop working after the license renewal.
Basically what happened was the trial license expired so i added the new license.
Cisco Unity Express V8.6.4
Thanks in advance!
Solved! Go to Solution.
05-13-2013 09:21 AM
Hi Sherwin,
I think u have uploaded the licenses but u need to activate them.
Please refer the POST for activation.
https://supportforums.cisco.com/docs/DOC-8218#Activating_Evaluation_Licenses
regds,
aman
05-14-2013 07:27 AM
Hi Sherwin,
You will need to go through the same process to activate the VM port(s) license
And then;
The Cisco CallManager Express configuration must include the creation of a voicemail number that is within the range of the destination pattern for the dial peer that you previously created. The voicemail number is the telephone number that is dialed when the Messages button on a Cisco IP phone is pressed, or a busy or unanswered call is forwarded to voicemail. Complete these steps in order to configure your voicemail phone number. In addition, ephone-dns must be configured to forward unanswered or busy calls to the voicemail number.
Enter the command enable in order to enter the EXEC mode.
Router>enable
Enter the command configure terminal in order to enter the configuration mode.
Router#configure terminal
Enter the command telephony-service in order to enter the telephony-service configuration mode.
Router(config)#telephony-service
Enter the command voicemail phone-number in order to define the number that is dialed when the Messages button is pressed.
Router(config-telephony-service)#voicemail 2000
Enter the command exit in order to finish the configuration.
Router(config-telephony-service)#exit
Enter the command ephone-dn dn-tag in order to enter the ephone-dn configuration mode to modify the extensions previously created.
Router(config)#ephone-dn 11
Enter the command call-forward busy directory-number in order to configure the call forwarding so that incoming calls to a busy extension are forwarded to voicemail.
Router(config-ephone-dn)#call-forward busy 2000
Enter the command call-forward noan directory number timeout seconds in order to configure the call forwarding so that incoming calls to a no-answer extension are forwarded to voicemail.
Router(config-ephone-dn)#call-forward noan 2000 time 10
Enter the command end in order to finish the configuration.
Router(config-ephone-dn)#end
Note: Repeat steps 6-9 on all the Cisco IP Phones connected to the system.
Cheers!
Rob
"Talk about a dream
Try to make it real"
- Springsteen
05-13-2013 09:17 AM
Hi Sherwin,
Are you sure the license was installed?
Go to System Setting-> Licenses: New licence should appear as Installed (Yes) and Demo licensed as Installed (No). If license are installed but it not working, try restarting the service or the server.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
05-13-2013 09:21 AM
Hi Sherwin,
regds,
aman
05-13-2013 09:33 AM
You need to remove the expired trial license.
05-13-2013 10:32 AM
Gentlemen thank you all for the quick responses, I will verify all your "thoughts" and will keep you posted.
I am pretty new to Cisco and Voice but I'm challenge and happy learning it everyday...
05-13-2013 11:43 AM
Yes,
After installing new licenses on the CUE module, you have to active the licenses with the command:
license active [ports/ voicemail mailboxes]
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
05-14-2013 06:15 AM
Sorry for the delay for this is an offsite branch.
Amanso thank you! and for all the other responses thank you!
One more thing and ive been doing dome reading and research, how come when the message button is pushed it goes to busy signal?
05-14-2013 07:27 AM
Hi Sherwin,
And then;
Router>enable
Cheers!
Rob
"Talk about a dream
- Springsteen
05-14-2013 08:45 AM
HI Rob,
Thanks for the input.
I just want to make sure that I understand this, the Voicemail is already set up. After activating the license by following https://supportforums.cisco.com/docs/DOC-8218#Activating_Evaluation_Licenses; now i have to do
"The Cisco CallManager Express configuration must include the creation of a voicemail number that is within the range of the destination pattern for the dial peer that you previously created. The voicemail number is the telephone number that is dialed when the Messages button on a Cisco IP phone is pressed, or a busy or unanswered call is forwarded to voicemail. Complete these steps in order to configure your voicemail phone number. In addition, ephone-dns must be configured to forward unanswered or busy calls to the voicemail number.
See Below:
ccn trigger sip phonenumber 8500
application "voicemail"
enabled
locale "en_US"
maxsessions 10
end trigger
TB-CUE# sh license all
License Store: Primary License Storage
StoreIndex: 0 Feature: VMIVR-VM-MBX Version: 1.0
License Type: Permanent
License State: Active, In Use
License Count: 30 /30
License Priority: Medium
StoreIndex: 1 Feature: VMIVR-PORT Version: 1.0
License State: Active, Not in Use
License Count: 4 / 0
License Store: Evaluation License Storage
License Type: Evaluation
License State: Inactive
Evaluation total period: 8 weeks 4 days
Evaluation period left: 0 minute 0 second
License Count: 600 / 0
License Priority: Low
License Count: 60 / 0
StoreIndex: 2 Feature: VMIVR-IVR-SESS Version: 1.0
License State: Active, Not in Use, EULA not accepted
Evaluation period left: 8 weeks 4 days
License Priority: None
05-15-2013 05:40 AM
Gentlemen, Thank you...Issue resolved!
