02-03-2011 06:55 AM - edited 03-16-2019 03:15 AM
Hi Support,
i read that for configuring VoIP, you must considere codec points, the code G.711 and G.729A.
I want to know regarding configuring routers or swicthes, how can i chose one or other codec?
How can i decide to use G.711 or another codec?
Solved! Go to Solution.
02-03-2011 08:24 AM
The configuration depends on the call control agent you'll be using.
Most usually you choose the codec based on the BW you have or the MOS you need.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
02-03-2011 08:35 AM
Each codec provides a certain quality of speech. The quality of transmitted speech is a subjective response of the listener. A common benchmark used to determine the quality of sound produced by specific codecs is the mean opinion score (MOS). With MOS, a wide range of listeners judge the quality of a voice sample (corresponds to a particular codec) on a scale of 1 (bad) to 5 (excellent). The scores are averaged to provide the MOS for that sample. This table shows the relationship between codecs and MOS scores.
Compression Method | Bit Rate (kbps) | MOS Score | Compression Delay (ms) |
G.711 PCM | 64 | 4.1 | 0.75 |
G.726 ADPCM | 32 | 3.85 | 1 |
G.728 LD-CELP | 16 | 3.61 | 3 to 5 |
G.729 CS-ACELP | 8 | 3.92 | 10 |
G.729 x 2 Encodings | 8 | 3.27 | 10 |
G.729 x 3 Encodings | 8 | 2.68 | 10 |
G.729a CS-ACELP | 8 | 3.7 | 10 |
G.723.1 MP-MLQ | 6.3 | 3.9 | 30 |
G.723.1 ACELP | 5.3 | 3.65 | 30 |
This document will help you understand about codecs
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a00800b6710.shtml
02-03-2011 01:42 PM
Depends on the Bandwidth
Inter-site -- G729
Intra-site - G711/G722
There's a slight difference between G711 and G729 audio quality..but a user wouldn't notice this in the course of a conversation.
PS: Rate useful posts.!
02-03-2011 03:02 PM
Assuming you're using H323 in the VOIP dial peer config mode just type codec ? and you'll get the list of options.
java
02-03-2011 03:12 PM
IP Phone A----- R1 ------ R2 --- IP Phone B
A(1000) calls B(2000)
R1 - Outgoing Dial-peer
dial-peer voice 2000 voip
destination-pattern 2...
session-target ipv4:
codec g729
R2 - incoming Dial-peer
dial-peer voice 9999 voip
incoming-called number 2...
codec g729
now the call hits Phone B as a G729 call :-)
If you are using CUCM use "regions"
02-03-2011 03:14 PM
This post helps you to understand dial-peer matching...
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
PS: Rate useful posts..
02-03-2011 08:24 AM
java
02-03-2011 08:35 AM
02-03-2011 01:42 PM
Inter-site -- G729
02-03-2011 01:44 PM
Thanks for your quick response
but can you please provide me with an example
if i have a wan link 512 kb/s, how can i choose code?
do you have router commande to choose codec?
regars
02-03-2011 03:02 PM
java
02-03-2011 03:12 PM
codec g729
codec g729
02-03-2011 04:17 PM
Thanks for your quick supports
02-03-2011 03:14 PM
