VoIP and VPN
sandman420
I have a question about some voip/vpn configuration. I've got two sites that have 1760 routers with fxo/fxs cards that are going to be tieing the two phone systems together with a couple of voip trunks. These are secondary devices on the network with no data traffic or real LAN even, but addressed with a 2nd wan ip on the fa 0/0 port. The only traffic going through these routers is voice/voip.
My question is about this voip setup with vpn. First off, should I or shouldn't I? If I configure a site-to-site vpn connection, will the voip traffic pass over that? How would I set up a VPN tunnel for only the fxo/fxs cards with no "LAN" behind it? Is there a need to have a vpn? Any benefits to sending the voip data across vpn, other than the obvious encryption of the "call"?
Here's my voip configuration as it sits on the bench in testing; I have both fa 0/0 interfaces connected to the local LAN just for a connection and testing, but each will later be getting it's own static WAN IP on the fa 0/0 interfaces:
SITE 1:
version 12.4
hostname SITE 1
boot-start-marker
boot-end-marker
enable secret XXX
no aaa new-model
voice-card 2
voice-card 3
ip cef
interface FastEthernet0/0
ip address 192.168.254.30 255.255.255.0
speed auto
no shutdown
no ip http server
no ip http secure-server
control-plane
voice-port 2/0
connection plar opx 290
voice-port 2/1
connection plar opx 291
voice-port 2/2
voice-port 2/3
voice-port 3/0
connection plar 190
voice-port 3/1
connection plar 191
voice-port 3/2
voice-port 3/3
dial-peer voice 180 pots
destination-pattern 180
port 2/0
dial-peer voice 181 pots
destination-pattern 181
port 2/1
dial-peer voice 190 voip
destination-pattern 19
session target ipv4:192.168.254.40
line con 0
logging synchronous
line aux 0
line vty 0 4
password xxx
logging synchronous
login
transport input telnet
end
AND SITE 2:
version 12.4
hostname SITE 2
boot-start-marker
boot-end-marker
enable secret XXX
no aaa new-model
voice-card 2
voice-card 3
ip cef
ip address 192.168.254.40 255.255.255.0
speed auto
no ip http server
control-plane
voice-port 2/0
connection plar opx 280
voice-port 2/1
connection plar opx 281
voice-port 2/2
voice-port 2/3
voice-port 3/0
connection plar 180
voice-port 3/1
connection plar 181
voice-port 3/2
voice-port 3/3
dial-peer voice 190 pots
destination-pattern 190
port 2/0
dial-peer voice 191 pots
destination-pattern 191
port 2/1
dial-peer voice 180 voip
session target ipv4:192.168.254.30
line con 0
logging synchronous
line aux 0
line vty 0 4
password xxx
logging synchronous
login
end
sandman420
Does nobody know about this type of setup? Is there anyone that can help me please?
You will probably get better answers if you post this over in some of the VPN forums. I'm guessing most people here are going to be more familiar with the voice configuration rather than the VPN design.
-nick
Nick,
I would, but I already have. I've got like 4x posts going for the last couple of weeks, just keep adding another one in different topics, like VPN, Unified C & V both in general and Video over IP (b/c I thought it had said Voice), as well as several other areas, but no one responds to me. I don't know where else I'm supposed to go to get help on this.
