VOIP between (2) 1552 Wireless Bridge. Should I use G.729?
Hello all,
I have this scenario where we have about 15 cisco phones at a remote site which is pretty much across the street and they are connected via 2 1552 wireless bridges outdoor.  Currently we are using CUCM 8.5 with that region is using G.711.  I started to notice some quality issues between this site.  I was thinking of dropping it down to G.729 as the 1552 Wireless Bridge do not support Qos.  It is best effort only.  Any input is appreciated.
11 Replies 11
paolo bevilacqua
Contrary to common belief, G.729 behaves worst than G.711 in presence of packet loss. A better codec, perhaps, would be iLBC. However I have many customer using wirelss and everything works perfectly without any QoS configures, so I recommend you check the antenna for perfect alignement, etc.
