Showing results forĀ
Search instead forĀ
Did you mean:Ā
VOIP Different Vlan
fadelelali
Dear
our company has two department (same location),i need to install IP Telephone in these two differents .each department has VLAN and i want to use Different voice VLAN for each department.
i have CME installated in our main router.how i can manage dofferent Voice VLAN in the router?do i have to create different configuration for each voice VLAN ?
any example or tutorial would be very thankful
thanks
Fadel
Jaime Valencia
If everything is going back to that ISR, simply configure router on a stick, you can google the term and find a lot of resources.
Unless you need assistance on the actual CME config, you might want to move this to a routing/switching community.
In the end, CME doesn't care about the underlying routing/switching, as long as it's configured so that phones can directly reach each other, and reach CME for signaling, MOH, etc.
java
if this helps, please rate
i got it
thanks alot
