Voip enable E3000
imikerae0
My name is Mike Rae and I am trying to get Voip working via Pennytel here in Australia.
I have the following setup:
Modem: Siemens Speedstream 4200 that signs on to Bigppnd ISP and passes an IP address to the router. DMZ is disabled.
Router: Cisco E3000 with Firewall disabled and ports 5060-5061 port forwarded to the ATA.
Cisco PAP2T ATA: Setup to Pennytel specs.
Problem:
I can receive calls. When I do I there is no incoming voice but the caller can hear me.
I cannot call out. There are no error messages, only silence and after a time the repetitive beeps of timing  out.
Request:
I think the problem is in the E3000 setup? The Modem does very little and the ATA is setup to Pennytel specs. Can anyone help with areas or settings I should look at? I would be grateful for any advice.
ATA settings follow:
Voice
Phone Adapter with 2 Ports for Voice-Over-IP
PAP2
Advanced View (switch to basic view) User Login
System Information
DHCP:EnabledCurrent IP:192.168.1.145
Host Name:LinksysPAPDomain:BigPond
Current Netmask:255.255.255.0Current Gateway:192.168.1.1
Primary  DNS:10.0.0.138
Secondary  DNS:192.168.1.1
Product Information
Product Name:PAP2TSerial Number:FL18H5081895
Software Version:5.1.6(LS)Hardware Version:5.1.5
MAC Address:0014BF8F1895Client Certificate:Installed
Customization:Open
System Status
Current Time:8/25/2011 22:49:31Elapsed Time:1 day and 00:50:24
Broadcast Pkts Sent:0Broadcast Bytes Sent:0
Broadcast Pkts Recv:583439Broadcast Bytes Recv:35404833
Broadcast Pkts Dropped:0Broadcast Bytes Dropped:0
RTP Packets Sent:0RTP Bytes Sent:0
RTP Packets Recv:0RTP Bytes Recv:0
SIP Messages Sent:87SIP Bytes Sent:62850
SIP Messages Recv:67SIP Bytes Recv:30996
External IP:
Line 1 Status
Display Name:8889333168User ID:8889333168
Hook State:OnRegistration State:Online
Last Registration At:8/25/2011 22:46:55Next Registration In:3414 s
Message Waiting:NoCall Back Active:No
Last Called Number:
Last Caller Number:0755915037
Mapped SIP Port:
Call 1 State:IdleCall 2 State:Idle
Call 1 Tone:NoneCall 2 Tone:None
Call 1 Encoder:
Call 2 Encoder:
Call 1 Decoder:
Call 2 Decoder:
Call 1 FAX:
Call 2 FAX:
Call 1 Type:
Call 2 Type:
Call 1 Remote Hold:
Call 2 Remote Hold:
Call 1 Callback:
Call 2 Callback:
Call 1 Peer Name:
Call 2 Peer Name:
Call 1 Peer Phone:
Call 2 Peer Phone:
Call 1 Duration:
Call 2 Duration:
Call 1 Packets Sent:
Call 2 Packets Sent:
Call 1 Packets Recv:
Call 2 Packets Recv:
Call 1 Bytes Sent:
Call 2 Bytes Sent:
Call 1 Bytes Recv:
Call 2 Bytes Recv:
Call 1 Decode Latency:
Call 2 Decode Latency:
Call 1 Jitter:
Call 2 Jitter:
Call 1 Round Trip Delay:
Call 2 Round Trip Delay:
Call 1 Packets Lost:
Call 2 Packets Lost:
Call 1 Packet Error:
Call 2 Packet Error:
Call 1 Mapped RTP Port:
Call 2 Mapped RTP Port:
Call 1 Media Loopback:
Call 2 Media Loopback:
imikerae0
I have discovered that the Siemens modem provided by Telstra blocks port 5060. This disables VoiP. I am going to replace the modem. Any suggestions?
