06-04-2014 12:04 PM - edited 03-16-2019 11:00 PM
We're preparing to migrate from an old Nortel system in our Tokyo office to Cisco VoIP. I'm starting to finalize the equipment for the site, and I realized that Japan, at least at one point in time, had a specific type of PRI (J1 I think). Has anyone done a similar migration from a TDM system to Cisco, and can you help me understand if they do in fact have a special type of PRI (which means I need a special VWIC...), or if they can use one of the VWIC3-MFT cards?
Solved! Go to Solution.
06-04-2014 12:19 PM
Scott,
You should be fine. Japan uses the same pri setup as US.
T1 Compliance (Partial List)
• ANSI T1.403
• US (UL 1950, T1)
• FCC Part 68
• CS-03
• Canada (CSA 950, T1)
• US (FCC Part 15 Class B, T1)
• U.K. (BS6301, EN60950, EN41003)
• Canada (CSA C108.8 Class A, T1)
• Bellcore-AT&T Accunet (62411)
• ATT 54016
• Japan (VCCI Class 2, VCCI:V-3/97.04, T1, JATE Green Book, IEC950)
http://www.cisco.com/c/en/us/products/collateral/routers/3600-series-multiservice-platforms/product_data_sheet09186a0080091b9c.html
http://www.cisco.com/c/en/us/products/collateral/routers/2800-series-integrated-services-routers-isr/data_sheet_c36-609138.html
Yosh
06-04-2014 12:19 PM
Scott,
• ANSI T1.403
• US (UL 1950, T1)
• FCC Part 68
• CS-03
• ATT 54016
Yosh
06-04-2014 12:20 PM
Awesome. Thanks Yosh. I remember hearing about the J1 way back in NetAcad, but haven't come across a deployment where I've had to worry about it until now.
Thanks for the assist!
SJ
06-04-2014 01:03 PM
Glad I could help out!
Yosh
06-04-2014 12:23 PM
Confirmed. I did one recently in Tokyo but it was during a move so we had a new PRI installed, and ported the numbers. No difference on the PRI than US.
06-04-2014 01:11 PM
Awesome. thanks Kevin.
SJ
