01-26-2018 01:46 AM - edited 03-17-2019 12:02 PM
I am currently using ISR4331 to setup a voice gateway with the image version of Cisco IOS XE Software, Everest-version 16.06.02. The error was appeared when the user try to making call using their IP telephony. I had tried to do some research and found the similar bugs with this issue but the affected version was not included with Everest-version 16.06.02. Kindly advise me for any solutions or actions able to carry out to overcome this issue? Thanks.
Reference: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvf84528/?referring_site=bugquickviewredir
Error Logs:
Jan 23 10:13:31.052: voip_rtp_allocate_port:Possible port leak? callID(18446744073709551615), port(8030) socket(0x0)
Jan 23 10:14:03.802: voip_rtp_allocate_port:Possible port leak? callID(18446744073709551615), port(8048) socket(0x0)
Jan 23 10:17:02.932: voip_rtp_allocate_port:Possible port leak? callID(18446744073709551615), port(8052) socket(0x0)
Jan 23 10:20:25.571: voip_rtp_allocate_port:Possible port leak? callID(18446744073709551615), port(8054) socket(0x0)
Jan 23 10:21:05.077: voip_rtp_allocate_port:Possible port leak? callID(18446744073709551615), port(8056) socket(0x0)
Jan 23 10:22:35.027: voip_rtp_allocate_port:Possible port leak? callID(18446744073709551615), port(8058) socket(0x0)
Jan 23 10:25:04.199: voip_rtp_allocate_port:Possible port leak? callID(18446744073709551615), port(8060) socket(0x0)
Jan 23 10:29:05.910: voip_rtp_allocate_port:Possible port leak? callID(18446744073709551615), port(8050) socket(0x0)
Jan 23 10:29:12.981: voip_rtp_allocate_port:Possible port leak? callID(18446744073709551615), port(8046) socket(0x0)
Jan 23 10:29:29.185: voip_rtp_allocate_port:Possible port leak? callID(18446744073709551615), port(8064) socket(0x0)
Jan 23 10:32:12.214: voip_rtp_allocate_port:Possible port leak? callID(18446744073709551615), port(8068) socket(0x0)
Jan 23 10:32:51.106: voip_rtp_allocate_port:Possible port leak? callID(18446744073709551615), port(8066) socket(0x0)
Jan 23 10:33:03.277: voip_rtp_allocate_port:Possible port leak? callID(18446744073709551615), port(8072) socket(0x0)
01-26-2018 06:42 AM
01-28-2018 05:37 PM
01-26-2018 08:03 AM
01-28-2018 05:40 PM
It does not have any call failures when call ongoing. I am curious that my version was 16.6 while affected version was 16.4(2), does it affected as well because of the same family on "16.0"?
Thank you for your assistance.
01-29-2018 07:41 AM
