VoIp setup over satellite
Hi All,
I have the following setup, 50 remote users are connected to HQ by satellite links (delay about 600 ms), each remote has 2 IP Phone where they are calling HQ.
I  don't have the option to add router(CM) for the remote can i use SIP protocol for such network with high delay
your suggestions are most welcome
Manish Gogna
As per the SRND, " If a voice service is hosted across a WAN where the one-way latency is 200 ms, for example, users might experience issues such as delay-to-dialtone or increased media cut-through delays. For other services such as presence, there might be no problem with a 200 ms latency." So, a delay of 600 ms will not provide a good user experience.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab09/clb09/models.html#pgfId-1044078
Manish
Thanks Manish for your response.
I understood the issue of have two CM servers talking to each other though high latency link.
i am wondering about the performance of call setup for SIP phone through such links; since the phone should communicate with SIP server during  call setup and ending.
Abdallah
One of my customers has a remote site with a response time of 240ms.
Originally we installed CUBE for PSTN breakout at the remote site but the MTP was using the resources on the CUCM and users were reporting very poor call quality and delaying in the phone operations.
We installed a Subscriber server on the remote site and reconfigured the CUBE to use the local subscriber server. Which works fine.
As Manish suggested 600ms will not give a good user experience if it even works at all!
Good luck!
Matty
