VoIP Telephony between 2 office locations in India
SteveSmith64782
Is it legal to use VoIP to route calls between 2 different office locations in different cities in a single company in India?
Please advice
2 Accepted Solutions
Vaijanath Sonvane
If your company offices are connected using IP network, then it is legal to use VoIP calls between the offices in India. The calls must be internal (extension-to-extension) calls over IP network and must not cross PSTN. TRAI regulates that IP to PSTN calls are not allowed as long as it bypass the toll otherwise it's allowed.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
5 Replies 5
Vaijanath Sonvane
Dear Vaijanath
Thank you for your reply. This is helpful. Can you please help me the following as well:
  • If the company has offices in different countries, let's say London, Singapore and Chennai, can they get SIP connectivity from the local service provider in India and then use VoIP calls between the offices in Chennai, Singapore and London (the calls are internal (extension-to-extension) calls over IP network and not crossing into PSTN). Is this allowed?
  • If the Chennai office also wants to connect to PSTN locally in India, can they have logical partitioning in their IP-PBX for PSTN and internal IP network, so that these 2 connections are separate and do not connect to each other? Is this allowed?
Please advise.
Yes on all your questions.
Response Signature
star 5 Helpful and accepted the earlier reply as a solution. I hope that's fine.
Accepted as a Solution and star 5 Helpful.
