voip
is there any way to give statics and ip phone number in cisco pakcet tracer?
without configuring dhcp
MxHadi
please say more about your problem,
i don't get it what's your mean..
-- if this helped, please rate by click (Accept as solution) or (Helpful) --
There is a 2801 router connected to the switch and a server-pt is connected to the switch, which distributes dhcp to computers
and the phones are connected to the switch, which is connected to the router.
computer should take dhcp through ip phone its address (192,168,1,50)
and the phone should get static address 192,168,10,2 and number 2505.
eyalraba
@jandosbaktanov87 ,
If you mean assigning a static IP address on the phone, you can do it from the phone's network setting on the phone itself, there's an option to disable the DHCP, and ou can assign the phone's, GW, subnet mask, and the TFTP IP address.
