VPN on SCCP phones
jonmo2578
Hi guys,
I came across this document earlier today regarding configuration of the SSL VPN client on SCCP phones to allow them to reach CME.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmevpn.html
I cant seem to find any related documents for CUCM 7.. Is this VPN option still possible or is it only supported into CME ?
We are running Call Manager 7.13.
Many thanks in advance for any information ..
Jon.
2 Accepted Solutions
Jaime Valencia
There's no documentation on CUCM 7 about this because this requires CUCM 8.5 or later.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Just a small point of clarification that the CUCM version is anything past CUCM 8.0.
There are also specific phone model and version requirements. Check out this doc I created a while back.
https://supportforums.cisco.com/docs/DOC-9124
Jaime Valencia
java
java
Cool.. thanks for the quick response guys..
