VRF Enabled Service-Engine Interface for CUE
AJAZ NAWAZ
Level 5
Level 5
Has anyone been able to successfully configure and TEST vrf enabled service-engine interface?. This is for CUE.
The option to configure vrf is there i.e.
service-enginer 1/0
vrf forwarding CUST-A
but once enabled I am told voicemail stops working.
thanks
Ajaz
7 Replies 7
beavisthrare1
I know this is an old post, but I am trying to get the same exact scenario to work. Has anyone been successful in getting a service module running CUE to work with VRF??
CUE is still not VRF aware, no. But you can get the vrf on the service engine:
voice vrf vrf2
ip vrf vrf2
rd 100:2
route-target export 100:2
route-target import 100:2
interface Service-Engine1/0 ip vrf forwarding vrf2
ip address 10.10.10.5 255.255.255.0 service-module ip address 10.10.10.6 255.255.255.0
service-module ip default-gateway 10.10.10.2
hth,
nick
Thanks for the quick response, Nick.
Here's the config from my router. When I attempt to add the 'voice vrf BEP', I get, ' % Cannot configure/unconfigure the CLI when VoIP services are running or when active VoIP calls are present'. There are no calls currently active, so what would I need to do to get around this?
Also, on the service engine, if I try to configure the IP address directly, it tells me it conflicts with Gig0/1, which is on the same subnet.
Any help is greatly appreciated!
Brian
I would imagine you'd have to shut down you service-engine interface...
or go furter. shutdown all interfaces and remember that you will have to re-apply your IP addrs after you enable vrf under each applicable interface.
let's see.
Ajaz
Try after this:
voice service voip
shutdown
Yes, I had tried shutting down the voip service and it let me add the voice vrf BEP. See attachment for the latest config. I'm still missing something as I can't get to the service module. Any suggestions?
Things look right, just make sure you're on 124-24T or later and this looks like it should work provided your VRF routing is in order.
-nick
