VWIC-1MFT-E1 not coming up
khanfawaz
I have a 2811 ISR with 12.4 IOS running on it. I have inserted VWIC-1MFT-E1= on the ISR and it is getting detected. In show inventory the
VWIC-1MFT-E1= is showing up. But it is not coming up.
Fawaz
5 Replies 5
ronpatel
Level 8
Level 8
What do you mean by not coming up? Is the controller is not coming up.
regards
Ronak patel
rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Ronak,
Thanks for the reply.
Yes I mean the controller is not coming up.
It can be number of issues when controller is not coming up.
1) Service provider issue
2) E1 Cable issue
3) Clocking issue.
etc
Send us the configuration and send the show controler output after clearing the counter.
Ronak patel
Rate helpful posts.
Hi Ronak,
This is a test environment and I am not terminating any PRI. I am using loopback to test the e1 card. Now the amber light is glowing on the e1 card, but if I plug in the loopback it should come up and green light should glow.
Right now the router is down. I cant take the configs. I will update once its up and running.
Thanks Ronak for the support.
Please post you configuration.
Chris
