l have set up a VOIP lab at home which include a router 2620XM, a switch 2950, five cisco ip phones, ATA 186 with 2 analog phones. All these devices are all connected and they are all ringing each other. But l have bought a VWIC G703 which l have installed to make a remote connection for the VOIP lab that l have set up. I will like to know if l can connect the 2 VWIC G703 together on two different routers will it work as a remote connection as if we are using a DTE/DCE connection like a WAN connection. And what cable will be appropriate to connect these routers together and what IOS should l use.
