04-10-2015 03:48 AM - edited 03-18-2019 11:30 AM
I am trying to register E1 and 8 FXO with CUCM 10.5 using mgcp. FXOs are showing registered in CUCM but not E1, it shows Unregistered. I have attached the Gateway configuration and screenshot CUCM. I am using Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(1)T3, REL
EASE SOFTWARE. Please let me if there is any mistakes in my configuration.
AD_Voice_GW#show ccm-manager
MGCP Domain Name: AD_Voice_GW
Priority Status Host
Primary Registered 10.20.13.9
First Backup Backup Ready 10.20.13.8
Second Backup None
Current active Call Manager: 10.20.13.9
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 14:39:48 GMT Apr 10 2015 (elapsed time: 00:00:12
Last MGCP traffic time: 14:39:48 GMT Apr 10 2015 (elapsed time: 00:00:12
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
Backhaul Link info:
Link Protocol: TCP
Remote Port Number: 2428
Remote IP Address: 10.20.13.9
Current Link State: OPEN
Statistics:
Packets recvd: 1
Recv failures: 0
Packets xmitted: 2
Xmit failures: 0
PRI Ports being backhauled:
Slot 0, VIC 0, port 0
Configuration Auto-Download Information
Current version-id: 1428657466-23cb555c-fb36-457e-81fa-58438df308d4
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
Download Attempted : 1
Download Successful : 1
Download Failed : 0
TFTP Download Failed : 0
Configuration Attempted : 1
Configuration Successful : 1
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command: New Registration
FAX mode: disable
Configuration Error History:
AD_Voice_GW#
D_Voice_GW#show isdn status
Global ISDN Switchtype = primary-net5
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not appl
y
ISDN Serial0/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
SHUTDOWN
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x00000000
Number of L2 Discards = 0, L2 Session ID = 0
Total Allocated ISDN CCBs = 0
AD_Voice_GW#
AD_Voice_GW#show mgcp endpoint
Interface E1 0/0/0
ENDPOINT-NAME V-PORT SIG-TYPE ADMIN
S0/SU0/ds1-0/1@AD_Voice_G 0/0/0:15 none up
S0/SU0/ds1-0/2@AD_Voice_G 0/0/0:15 none up
S0/SU0/ds1-0/3@AD_Voice_G 0/0/0:15 none up
S0/SU0/ds1-0/4@AD_Voice_G 0/0/0:15 none up
S0/SU0/ds1-0/5@AD_Voice_G 0/0/0:15 none up
S0/SU0/ds1-0/6@AD_Voice_G 0/0/0:15 none up
S0/SU0/ds1-0/7@AD_Voice_G 0/0/0:15 none up
S0/SU0/ds1-0/8@AD_Voice_G 0/0/0:15 none up
S0/SU0/ds1-0/9@AD_Voice_G 0/0/0:15 none up
S0/SU0/ds1-0/10@AD_Voice_ 0/0/0:15 none up
S0/SU0/ds1-0/11@AD_Voice_ 0/0/0:15 none up
S0/SU0/ds1-0/12@AD_Voice_ 0/0/0:15 none up
S0/SU0/ds1-0/13@AD_Voice_ 0/0/0:15 none up
S0/SU0/ds1-0/14@AD_Voice_ 0/0/0:15 none up
S0/SU0/ds1-0/15@AD_Voice_ 0/0/0:15 none up
S0/SU0/ds1-0/17@AD_Voice_ 0/0/0:15 none up
S0/SU0/ds1-0/18@AD_Voice_ 0/0/0:15 none up
S0/SU0/ds1-0/19@AD_Voice_ 0/0/0:15 none up
S0/SU0/ds1-0/20@AD_Voice_ 0/0/0:15 none up
S0/SU0/ds1-0/21@AD_Voice_ 0/0/0:15 none up
S0/SU0/ds1-0/22@AD_Voice_ 0/0/0:15 none up
S0/SU0/ds1-0/23@AD_Voice_ 0/0/0:15 none up
S0/SU0/ds1-0/24@AD_Voice_ 0/0/0:15 none up
S0/SU0/ds1-0/25@AD_Voice_ 0/0/0:15 none up
S0/SU0/ds1-0/26@AD_Voice_ 0/0/0:15 none up
S0/SU0/ds1-0/27@AD_Voice_ 0/0/0:15 none up
S0/SU0/ds1-0/28@AD_Voice_ 0/0/0:15 none up
S0/SU0/ds1-0/29@AD_Voice_ 0/0/0:15 none up
S0/SU0/ds1-0/30@AD_Voice_ 0/0/0:15 none up
S0/SU0/ds1-0/31@AD_Voice_ 0/0/0:15 none up
aaln/S0/SU1/0@AD_Voice_GW
aaln/S0/SU1/1@AD_Voice_GW
aaln/S0/SU1/2@AD_Voice_GW
aaln/S0/SU1/3@AD_Voice_GW
aaln/S0/SU2/0@AD_Voice_GW
aaln/S0/SU2/1@AD_Voice_GW
aaln/S0/SU2/2@AD_Voice_GW
aaln/S0/SU2/3@AD_Voice_GW
AD_Voice_GW#
Solved! Go to Solution.
05-04-2015 12:45 AM
Thank you,
I didn't noticed that, may by someone manually given these commands. I only gave ccm-manager and ccm-manager config server x.x.x.x and mgcp. All other configuration is from cucm 10.5, at least I thought :-p.
So you think this made the interface active.
05-04-2015 04:12 AM
Since ISDN Layer 1 was showing as Deactivated/Shutdown,so , framing crc4 could be main cause.
regds,
aman
05-05-2015 02:22 AM
Thank you, me too thinks same
05-03-2015 03:49 AM
Hi.
It's a common troubleshooting step to reload the route if e1 doesn't go up after configuring mgcp.
That could have fixedly your issue.
Carlo
05-03-2015 12:26 AM
Thank you. I swapped from modem side, but no use. Still showing shutdown. When checked with service provider they infomed for framing use CRC is disabled.
05-03-2015 12:47 AM
