VWIC3 - straight cable, RJ48C, or both?
gesnaudniji
Hello there,
In the past i wroked with VWIC1 or 2, and i had the habit to uses RJ48 pinout only to bind telco access point to the Cisco's voice card (as wrote down here).
Today, i had to play with a VWIC3, and my fellows told me that i don't have to use RJ48, straight RJ45 will be sufficient...
  • is that true?
  • Where can I find official documentation?
  • Is a RJ48C could work too on VWIC3?
  • For previous VWIC, is the straight RJ45 could work too?
Thx again!
Greg
2 Accepted Solutions
Ayodeji Okanlawon
Greg,
I have always used straight through RJ45 and it works. Never used RJ48
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Hi Greg,
You need to use 1,2 and 4,5 pin on the RJ-45 connector.Your controller should come UP.In case,if it does not come UP,swap the Tx and Rx pairs on either side.
refer the URL
https://supportforums.cisco.com/docs/DOC-9474
regds,
aman
5 Replies 5
Ayodeji Okanlawon
Greg,
Hi Greg,
refer the URL
regds,
aman
Ayodeji Okanlawon
Another thread confirming this..
https://supportforums.cisco.com/thread/188997
hi guys,
Thx for your answer...
As i was googling my question, i found also that E1 would use 1,2 & 7,8... is that correct too?
Thx again!
Hi Greory
Greg is right.
its Pin 1,2 and 4,5. For Transmit and Receive.
