Wallpaper on CIUS from CUCM?
Hes
Is it possible to get and set a wallpaper from CUCM on the Cisco Cius?
I can't find anything on this in the administrator guide on this also not on what the optimal resolution is, I guess
1024 x 600..
Jaime Valencia
No, I'm afraid that's not possible
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Gajanan Pande
Rachid,
Yes, the wallpaper resolution by default will be 1024 x 600 as mentioned in the data sheet here http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps7290/ps11156/data_sheet_c78-609507.html
But I found out the best size for background should be 2048 x 600, which CIUS supports very much.
You should be able to use background images being used by any other phones or create a special/customized one for CIUS & then push it to TFTP server.
GP.
Pls rate helpful posts !!
What should the folder name be in order to be able to select the wallpaper from the Cius via TFTP?
/Desktops/1024x600x24/ or something ?
I have no clue which directory name I must use to place the List.xml and where to find this info.
