WAN bandwidth requirements for small setups of about a 1000 phones
Nicolas Mansour
Hi there,
I searched the SRND for bandwidth requirements for clusters over the WAN. The only thing I found is a formula for clusters with a BHCA of over 10,000. Using the following formula:
Total Bandwidth (Mbps) = (Total BHCA/10,000) ∗ (1 + 0.006 ∗ Delay), where Delay = RTT delay in msec
My question is the 10,000 a fixed number to use this forumal ? or is there any other way to calculate the WAN requirements?
Thank you in advance.
Nick
Jaime Valencia
The formulas are here
Bandwidth Provisioning
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/netstruc.html#wp1044772
This is only for the signaling, the DB is fixed at a T1 speed + signaling.
java
if this helps, please rate
java
