02-28-2013 03:26 PM - edited 03-16-2019 03:59 PM
Hi everyone, I'm troubleshooting a small issue and I can't seem to wrap my head around how this specific scenrio is supposed to be configured.
I'm tryign to figure out how to get one Cisco 2811 ISR with multiple 2MFT-T1 cards in it to pass calls between the different voice ports.
For example, if you look at the diagram, I am just setting up failover. WAN comes down and calls should reroute over the PRI via the PSTN to the Remote site. My question is, how does the simulated PSTN need to be configured to allow calls coming in from the HQ site on one physical/logical voice port and pass the call out to another physical/logical voice port to reach a phone on the Branch router?
I have all my dial-peers in place and are translating the 4 digit extensions from the local sites to 10 digit numbers when hitting the PSTN. On the PSTN I'm translating the 10 digits back down to 7 digit local numbers for each site and on each site taking the numbers down to 4 digits to ring the phones on their internal extensions.
What I'm not clear on is how does the PSTN router route the calls between the two PRI's? I'm seriously having a brain fart, again. Calls from the PSTN can be placed to each site just not between the PSTN from each site.
02-28-2013 04:06 PM
Ralph,
Something like this will do the trick :-
hostname PSTN
dial-peer voice 2000 pots
desc *** TO BRANCH ***
destination-pattern 818831...
incoming called-number .
port 0/1/0:23
forward-digits all
dial-peer voice 8000 pots
desc *** TO HQ ***
destination-pattern 2125472......
port 0/0/0:23
forward-digits all
Alex.
Please rate useful posts.
02-28-2013 07:55 PM
I think there were a couple of small errors in your reply Alex but correct me if I'm wrong.
Here is what I have configured on the PSTN Router:
dial-peer voice 101 pots
destination-pattern 831....
port 0/0/0:23
prefix 831
dial-peer voice 322 pots
destination-pattern 547....
port 0/1/0:23
prefix 547
dial-peer voice 3002 pots
port 0/1/0:23
forward-digits all
dial-peer voice 3001 pots
destination-pattern 8138311...
port 0/0/0:23
forward-digits all
dial-peer voice 1 pots
direct-inward-dial
3002 is used to route calls via the PRI to the Branch location
3001 to the HQ location based on the topology
When I debug q931 from each router:
HQ OUTBOUND to PSTN
Mar 1 03:47:41.587: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Calling num 8138311001
Mar 1 03:47:41.587: ISDN Se0/0/0:23 Q931: Sending SETUP callref = 0x0083 callID = 0x8004 switch = primary-ni interface = User
Mar 1 03:47:41.587: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0083
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98384
Exclusive, Channel 4
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x2180, '8138311001'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '2125472001'
Mar 1 03:47:41.607: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8083
Cause i = 0x8081 - Unallocated/unassigned number
PSTN INBOUND from HQ
Mar 1 03:53:39.022: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0083
Standard = CCITT
Mar 1 03:53:39.030: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8083
Basically same output from the branch location to the PSTN.
As you can see, I'm translating the calling party number from the HQ location from the 4 digit 1001 to the 10 digit 8138311001. I also wrote a translation for the Called Party Number.
On the PSTN however, I don't have any translations because I'm send the 10 digits to the Branch location. At the Branch location and HQ location I'm stripping off the first 7 digits using a translation rule.
Example:
voice translation-rule 1
rule 1 /^\(1...\)$/ /813831\1/
voice translation-rule 2
rule 1 /^831/ //
voice translation-rule 3
rule 1 /^\(2...\)$/ /212547\1/
voice translation-profile CALLID_OUT
translate calling 1
voice translation-profile PSTN_ALT_OUT
translate called 3
voice translation-profile PSTN_IN
translate called 2
Applied to the alternate PRI dial-peer on the HQ router:
dial-peer voice 302 pots
translation-profile outgoing PSTN_ALT_OUT
preference 2
destination-pattern 2...
no digit-strip
port 0/0/0:23
forward-digits all
I feel this should work but haven't found a solution yet as to why it does. I may need to translate at the PSTN and send down 7 digits instead of 10 to the branch location but it doesn't appear the PSTN router is sending anything to the branch location when I place a call from the HQ router using a 4 digit number of the branch location.
