Want to add a new voice card
divine007
My cisco 2800 series has a voice E1 card of xtics
PVDM Slot 0:
        16-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
        Hardware Revision        : 4.0
        Part Number              : 73-8538-05
        Board Revision           : B0
        Deviation Number         : 0
        Fab Version              : 04
        PCB Serial Number        : FOC114530JX
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM2-16
        Version Identifier       : V01
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 03 EF 41 04 00 82 49 21 5A 05 42 42 30
          0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 31 34 35
          0x20: 33 30 4A 58 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 88 50 56 44 4D 32 2D 31 36 89 56 30 31 20 D9 02
          0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Now i want to get a 32 channel voice card.
How can i get it an its compatibilities!
gregorygout
Hi Divine,
2800 series do not support PVDM 3:
http://www.cisco.com/en/US/prod/collateral/modules/ps3115/data_sheet_c78-553971.html
PVDM3 modules are not supported on the existing Cisco 2800 and 3800 Series Integrated Services Routers.
You need to check with your version of 2800 (11,21,51 ?) how many PVDM2 it can takes.
Cheers,
Greg
Hi Ambe,
Refer the link for voice cards support on ISR routers.
https://www.cisco.com/en/US/prod/collateral/routers/ps10538/aag_c07_563807.pdf
regds,
aman
