250
Highlighted
Beginner
Warning! DSPs1 in slot 0 are using non-default firmware from flash:
hi,
C2801-ADVIPSERVICESK9-M), Version 15.0(1)M9
PID: PVDM2-16
when I reload the router I get this message something about firmware for the dsps not sure what to do about it.
RTR#sh voice dsp
edsp 0001 01 g729r8 p  0.1 IDLE  50/0/11.1
edsp 0002 02 g729r8 p  0.1 IDLE  50/0/11.2
edsp 0003 01 g729r8 p  0.1 IDLE  50/0/12.1
edsp 0004 02 g729r8 p  0.1 IDLE  50/0/12.2
edsp 0005 01 g729r8 p  0.1 IDLE  50/0/13.1
edsp 0006 02 g729r8 p  0.1 IDLE  50/0/13.2
edsp 0007 01 g729r8 p  0.1 IDLE  50/0/75.1
edsp 0008 01 g729r8 p  0.1 IDLE  50/0/76.1
----------------------------FLEX VOICE CARD 0 -----------------------
                           *DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND     : (bad)bad    (shut)shutdown  (dpend)download pending
DSP    DSP                 DSPWARE CURR  BOOT                         PAK   TX/RX
TYPE   NUM CH CODEC        VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
                           *DSP SIGNALING CHANNELS*
C5510  001 01 {flex}       26.3.12 alloc idle      0  0 0/0/0     02    0         37/0
C5510  001 02 {flex}       26.3.12 alloc idle      0  0 0/0/1     06    0         37/0
C5510  001 03 {flex}       26.3.12 alloc idle      0  0 0/0/2     10    0         37/0
C5510  001 04 {flex}       26.3.12 alloc idle      0  0 0/0/3     14    0         37/0
------------------------END OF FLEX VOICE CARD 0 ----------------------------
it all seems fine to me but I don't understand why the router is giving that message and if I should do something about it.
this is happening because I updated the IOS to the above version.
I thought I had nothing to do to update the dsp firmware that it was integrated in the ios.
any thoughts?
thanks.
1 REPLY 1
Highlighted
Advisor
I read some earlier discussions and referred the  DOC but could not find anything concrete and the compatible DSP firmware version with your running IOS.
http://www.cisco.com/c/en/us/support/docs/voice/voice-quality/109469-dspware-c5510dsp.html
Also, some discussions say opening  a TAC case to get the desired rbf file and uploading the same in flash of router.You can try the same.
regds,
aman
