08-10-2012 03:14 AM - edited 03-16-2019 12:38 PM
we experiencing a problem in RTMT syslog messages, there are a lot of these message :
WARNING : /etc/modprobe.conf line 9: ignoring bad line starting with 'if'
WARNING : /etc/modprobe.conf line 11: ignoring bad line starting with 'endif'
I have'nt any problem on the CUCM, but the syslog is full of this messages and i can see any other alarm.
Version 7.0.2.20000-5
Thank you in advance.
Fabrizio
Solved! Go to Solution.
08-10-2012 03:18 AM
HI
It is cosmetic issue.
Ronak Patel
Rate helpful posts.
08-10-2012 03:18 AM
HI
Ronak Patel
Rate helpful posts.
08-10-2012 03:20 AM
thank you for your answer.
I wil update the version.
Fabrizio
