Weather Audio Alert on CUCM - Paging
Shaijala
Dear All,
We have a requirement to have a weather audio alert system on cisco ip phones. All the phones should receive some kind of audio alert (beep,messages) if there's any weather change. Is it possible to do it without using third party applications ?. If not, could somebody recommend a good solution (third party solutions) for us.
Current CUCM Version - 7.x
Shaijal
Jaime Valencia
No, at least not on that version.  You need a 3rd party
On 9.1 you do get that via a Singlewire
https://supportforums.cisco.com/thread/2190897
You might want to look into that one.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
kelvin.blair
Level 5
Level 5
As Jaime stated there is no native application to do this with CUCM.  However, per your second request here are a few third party applications that should meet your requirements.
http://www.athoc.com/products/weather-alerting-module.html
http://www.singlewire.com/
http://www.syn-apps.com/solutions/emergency-notification/
