Webdialer ccm 4.2.3
dlieman
I have a problem using webdailer on a ccm 4.2.3 version.
When I use a country code the dialing takes forever.
So dailing 00612345678 goes without any problems the phone dials directly the number.
Putting 00031612345678 in front of the number and the phone won?t show the number until waiting for 15 second or pressing #.
The CCM is upgraded from a 4.1.3 version and it worked without any problems.
Even after upgrading to 4.2.1 it worked.
Has anyone noticed it to or maybe a solution?
thanks in advanced.
smalkeric
Level 6
Level 6
I am having the same issue. Before, the call was delivered to the phone by webdialer and it would go off hook and wait for the time out before putting the call through. Now, the call is sent to the phone, it goes off hook but you get dial-tone for 10 seconds and then it put the call through. This is what catches people out. They think it has broken and simply press EndCall on the phone.
The link above gives you no information that will help with this problem.
We have the same problem after the upgrade to CCM 4.2(3). I note that this happened also by calling with double click external speed dials, saved in the Attendant Console.
Is anywhere a timer to set?
Any idea about this error?
