Hi all,
Thank you in advance, want to ask if anyone recognise this warning, and if it is something that can be overcome in configuration.
I often have to login to muliple computers to do my work. Our office is with on-prem UC (CUCM, Unity, UCCX) and also have incorporated Webex Calling.
The graphic below is kind of telling me that my personal line cannot appear on multiple devices?
So when launching Webex (Teams) app on the second computer, the warning appears, per the graphic screen shot.
Solved! Go to Solution.
If it's registered to CUCM that has always been the case, the same happens with Jabber, the CSF device can only be used by one instance for registration to phone services. If one device is already using the CSF device you need to choose, either you leave it in the first device that got registered, or you move the registration to the new device. But only one will be registered at any given time. That's the expected behavior.
Thanks Jaime, and understand.
This is a fork in this question, a behaviour in my colleagues' working environment, and probably need some guidance to what logs/traces can explain the behaviour:
Am first guessing there's some CTI contention on the PC side, but maybe also the audio out on the PC is affected (cannot hear voip audio).
So a well loaded up Windows 10 PC, any thoughts welcome.
