07-30-2007 02:54 PM - edited 03-14-2019 10:50 PM
Hi All,
I was wondering if anyone could recommend a brand of Analog phone that the MWI would work on a VG224.
I think the 224's can only support audible MWI but if they can do lights that would be great.
I have a customer that needs some analogs that can do the MWI on the vg224 and i do not have a brand to recommend. None of the phones they currently have (analog) will do the MWI on the 224's
thanks for any help
07-30-2007 07:27 PM
VG224 does support VMWI on Analog phone with lamp (24v to 48v) light activation by frequency-shift-key (FSK) message.
Panasonic KX-TSC55-B is one that works.
http://www.sandman.com/messwait.html
Part Number: WAL2I
07-31-2007 05:33 AM
thanks!
I've been looking for awhile now to find somone that had one working :)
going to get one and test it out
thanks again
08-08-2007 06:19 AM
thanks again for the information :)
Do you have a vendor that sells these?
I found one, but not sure if its correct or not, it says its a 2 line phone
02-13-2008 12:16 PM
I recently purchased a "beehive" from the Mike Sandman at Chicago's Telecom Expert. I am unable to get it to work consistently with a vg224.
Does anyone have luck with getting these MWI FSK working with the vg224?
02-13-2008 12:23 PM
I wrestled with this for awhile. I actually found an AT&T 922 phone from Staples that worked for me.
I did here from a person I was working with at Teledex that cisco has fixed the FSK in this IOS version.
12.4(17.09)T
I have not tested though. Let me know if you try it and it works.
02-13-2008 12:24 PM
Also you definitely have to have the VG224 setup as SCCP instead of MGCP
02-13-2008 01:34 PM
Thanks! I definitely have the VG224 setup as SCCP, but I am running version 12.4(6)xe3. I will upgrade to see if that helps.
I noticed the FSK turns on and off properly on the vg224 when i refresh the MWI but the beehive does turn on/off consistently.
Mark
04-25-2008 03:35 AM
Mark,
Did you have any success getting this to work? If so what combination of code and MWI device did you find?
Dave
04-25-2008 05:42 AM
I did not since I am running CCM v4.1 and the VMWI is supported with v4.2 or higher.
05-12-2008 07:12 AM
I have finally found a phone which does do VMWI on a VG224. It's a BT Converse 1300, so long as the MWI type is set to '1571'.
The VG224 is running SCCP on 124-15.T2 IOS on a CUCM 6.1.1 system
However, other similar phones in the range do not appear to work at the moment, Converse 1200, Converse 225 & Decor 1300.
TAC case open with Cisco. Watch this space...
Alistair
05-12-2008 07:19 AM
Alistar,
Can you explain what you mean by setting the MWI type to '1571'? Is this some command on the VG224?
Dave
05-12-2008 07:32 AM
Hi Dave,
No, the setting is on the phone handset itself. There is a selector switch on the back for MW1, MW2, MW3 & 1571.
Funnily enough, there is the same switch on the Converse 1200 as well, but no joy with that one...
Cheers,
Alistair
06-05-2012 05:44 PM
Hello Alijames,
Just curious whether you know how CUCM or CME sends MWI to the analogue phones, does it do via:
1. Broken Dial Tone
OR
2. Burst of Ring (PRINGLE).
Cheers,
Hunt
06-22-2008 11:42 PM
TeleMatrix phones are working great for me.
