Walkthrough Wednesdays
42672
what debug for seeing DTMF tones via CUBE -SIP?
On a 3845 running 12.4 20, the DTMF tones (for menu options) are not getting passed from the PSTN into the network after the call is established.  The router is using CUBE software and passes the call to the PSTN via SIP trunking/SIP server.  The call is established at G729. I'm using debug voip ccapi inout and debug sip messages, but I don't see the digits being passed.
1.  Am I using the right debugs?  If not, which ones do I use?
2.  At G729, are the tones compressed, or are they out of band?
26 REPLIES 26
Was there a resolution to this issue?
Thanks.
Yes, there was a resolution.  It was the three debugs noted previously in the posts,
debug ccsip all
debug voip rtp sess name
I was looking for the digit 9 to pass through.  You can see it in the debug ccapi as "Relaying Digit 9 to dstCallId"
Can anyone suggest what Cisco DTMF method can be configured under the Dial-Peer that will transmit the digits within the g.7xx audio i.e. pure in-band DTMF payload ?
Tiberie
Hi Tiberie,
Not sure why would you want to do that but in that case you want to configure no dtmf-relay CLI under dialpeer to carry the dtmf digits in the voice codec.
HTH,
DK
Thanks Dilip,
The service provider SIP platform supports the DTMF standard under RFC2833  or in other words, pure in-band (DTMF tones in the actual audio stream). So, in some situation when the call goes to certain AA/IVR systems, the relayed DTMF tones are not relayed and properly recognized by the other side.
I've read that "rtp-nte" is not actualy doing in-band transmition of the DTFM tones, rather the digits are transmitted via data, not in-the-audio of the g.7xx codec.
That's why, I was asking if there is a way to configure the SIP dial-peers on the CUBE to send the compatible DTMF tones to the SP.
Wll try the "no dtmf-relay" metod.
Thank You for the assistance.
Tiberie
Hmm, if the SP SIP gear supports RFC2833 dtmf method then what you really want on the CUBE dialpeer is dtmf-relay rtp-nte. Some consider RFC2833 to be inband as dtmf  digits are carried in the RTP stream (using a different payload type than voice)
Infact rt-nte/rfc2833 is  actually out of band as dtmf is simply signaled using RTP events to the other side and not really processed through the voice codec.
Thanks.
DK
An UPDATE:
I used the commands:"dtmf-interworking standard" under the two dial-peers (cucm/cube & cube/SP) and the DTMF tones were transmitted/received fine from then onwards. The SIP SP is accepting only In-band tones for telephony events i.e. as part of the voice waveform. See http://tools.ietf.org/html/rfc4733#
While the command "dtmf rtp-nte" is sending telephony events out-of-band but within the RTP session, which is not in reality an in-band method.
Tiberie,
I am curious to see what the sip messages look like..can you do a test call to itsp and send debug ccsip messages
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Sure. But it might take me a while since the client mentioned to me that they are super busy today and the following week. Will update once I have the debug output.
HI aokanlawon ,
I finaly managed to get the debuf output from the "debug ccsip messages" and "debug voice ccapi inout" command.
Sorry for the long debug log, I don't have chance anywhere to upload the file. Also, I'm sending at the end, an output from the command "debug voip rtp session named-event"
Can You explain to me what's going on with the type of DTMF beeing transmitted?
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.02.19 17:18:31 =~=~=~=~=~=~=~=~=~=~=~=
Feb 19 17:21:03.254: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0038923248XXX@10.2.115.15:5060 SIP/2.0
Via: SIP/2.0/UDP 10.2.115.5:5060;branch=z9hG4bK4cce15b002c71
From: "Caller" <>;tag=659027~d01f1c4f-fe32-4ce8-bb98-06bd76f12320-33263464
To: <0038923248XXX>
Date: Wed, 19 Feb 2014 16:21:03 GMT
Call-ID: d2504700-3041d9ef-47e32-573020a@10.2.115.5
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM9.1
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Cisco-Guid: 3528476416-0000065536-0000002046-0091423242
Session-Expires:  1800
P-Asserted-Identity: "Caller" <>
Remote-Party-ID: "Caller" <>;party=calling;screen=yes;privacy=off
Contact: <>
Max-Forwards: 69
Content-Length: 0
Feb 19 17:21:03.258: //-1/D25047000000/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=+38923167XXX
   ----- ccCallInfo IE subfields -----
   cisco-ani=sip:+38923167XXX@10.2.115.5
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=sip:0038923248XXX@10.2.115.15:5060
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Feb 19 17:21:03.262: //-1/D25047000000/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x31340418, Call Info(
   Calling Number=sip:+38923167XXX@10.2.115.5,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=sip:0038923248XXX@10.2.115.15:5060(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=10, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=176022
Feb 19 17:21:03.262: //-1/D25047000000/CCAPI/ccCheckClipClir:
   In: Calling Number=sip:+38923167XXX@10.2.115.5(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=sip:+38923167XXX@10.2.115.5(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Feb 19 17:21:03.262: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 19 17:21:03.262: :cc_get_feature_vsa malloc success
Feb 19 17:21:03.262:  cc_get_feature_vsa count is 1
Feb 19 17:21:03.262: :FEATURE_VSA attributes are: feature_name:0,feature_time:833881656,feature_id:160387
Feb 19 17:21:03.262: //176022/D25047000000/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
Feb 19 17:21:03.262: //176022/D25047000000/CCAPI/cc_process_call_setup_ind:
   Event=0x31845110
Feb 19 17:21:03.262: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 0038923248XXX
Feb 19 17:21:03.262: //176022/D25047000000/CCAPI/ccCallSetContext:
   Context=0x2B07195C
   >>>>CCAPI handed cid 176022 with tag 10 to app "_ManagedAppProcess_Default"
Feb 19 17:21:03.262: //176022/D25047000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <0038923248XXX>
Date: Wed, 19 Feb 2014 16:21:03 gmt
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Feb 19 17:21:03.262: //176022/D25047000000/CCAPI/ccCallProceeding:
Feb 19 17:21:03.262: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
   mempool not found from usrContainer(31823634)
Feb 19 17:21:03.262: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
   Mempool(2AFD4B64) created in usrContainer(31823634)
Feb 19 17:21:03.266: //176022/D25047000000/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=20, Params=0x2B06551C, Progress Indication=NULL(0)
Feb 19 17:21:03.266: //176022/D25047000000/CCAPI/ccCheckClipClir:
   Destination Pattern=.T, Called Number=0038923248XXX, Digit Strip=FALSE
   Calling Number=sip:+38923167XXX@10.2.115.5(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=0038923248XXX(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=Caller
   Account Number=+38923167XXX, Final Destination Flag=TRUE,
   Guid=D2504700-0001-0000-0000-07FE0573020A, Outgoing Dial-peer=20
Feb 19 17:21:03.266: //176022/D25047000000/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=0038923248XXX
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Feb 19 17:21:03.266: //176022/D25047000000/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x31340418, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=sip:+38923167XXX@10.2.115.5,(Calling Name=Caller)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=0038923248XXX(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Feb 19 17:21:03.266: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 19 17:21:03.266: :cc_get_feature_vsa malloc success
Feb 19 17:21:03.266:  cc_get_feature_vsa count is 2
Feb 19 17:21:03.266: :FEATURE_VSA attributes are: feature_name:0,feature_time:833881880,feature_id:160388
Feb 19 17:21:03.266: //176023/D25047000000/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Feb 19 17:21:03.266: //176023/D25047000000/CCAPI/ccCallSetContext:
   Context=0x2B0654CC
Feb 19 17:21:03.266: //176022/D25047000000/CCAPI/ccSaveDialpeerTag:
Feb 19 17:21:03.266: //176023/D25047000000/CCAPI/cc_api_call_proceeding:
   Interface=0x31340418, Progress Indication=NULL(0)
Feb 19 17:21:03.270: //176023/D25047000000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:0038923248XXX@172.25.255.164:5060 SIP/2.0
Via: SIP/2.0/UDP 10.126.98.37:5060;branch=z9hG4bK31F165A
To: <0038923248XXX>
Call-ID: A9472160-98B811E3-897DFE89-917343ED@10.126.98.37
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1392826863
Contact: <>
Expires: 180
Max-Forwards: 68
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 331
v=0
o=CiscoSystemsSIP-GW-UserAgent 9057 1587 IN IP4 10.126.98.37
s=SIP Call
c=IN IP4 10.126.98.37
t=0 0
m=audio 19826 RTP/AVP 0 8 18 101 19
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
Feb 19 17:21:03.286: //176023/D25047000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <0038923248XXX>
CSeq: 101 INVITE
Feb 19 17:21:03.362: //176023/D25047000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
To: <0038923248XXX>;tag=SDraqe898-2700717777
CSeq: 101 INVITE
Content-Length: 0
Contact: <>
Server: Patton SN4940 1E30V 00A0BA097588 R6.T 2013-04-04_RFE2204 H323 RBS SIP M5T SIP Stack/4.1.12.18
Feb 19 17:21:03.362: //176023/D25047000000/CCAPI/cc_api_event_indication:
   Event=97, Call Id=176023
   Event Is Sent To Conferenced SPI(s) Directly
Feb 19 17:21:03.362: //176023/D25047000000/CCAPI/cc_api_call_cut_progress:
   Interface=0x31340418, Progress Indication=NULL(0), Signal Indication=NOT PRESENT(255),
   Cause Value=0
   Call Entry(Responsed=TRUE)
Feb 19 17:21:03.362: //176022/D25047000000/CCAPI/ccCallCutProgress:
   Progress Indication=NULL(0), Signal Indication=NOT PRESENT(255), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Feb 19 17:21:03.362: //176022/D25047000000/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <0038923248XXX>;tag=B8DD5C64-7FF
CSeq: 101 INVITE
Remote-Party-ID: <0038923248XXX>;party=called;screen=no;privacy=off
Contact: <0038923248XXX>
Content-Length: 0
Feb 19 17:21:03.506: //176023/D25047000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 0
Contact: <>
Feb 19 17:21:03.506: //176023/D25047000000/CCAPI/cc_api_call_alert:
   Interface=0x31340418, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Feb 19 17:21:03.506: //176022/D25047000000/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Feb 19 17:21:03.506: //176022/D25047000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Contact: <>
Content-Length: 0
Feb 19 17:21:03.730: //176023/D25047000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length: 274
Contact: <>
Supported: replaces
v=0
o=MxSIP 0 18772 IN IP4 172.25.255.196
s=SIP Call
c=IN IP4 172.25.255.196
t=0 0
m=audio 20452 RTP/AVP 0 8 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
Feb 19 17:21:03.734: //176023/D25047000000/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=176023,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Feb 19 17:21:03.734: //176022/D25047000000/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=176023, Source Call Id=176022,
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1348)
Feb 19 17:21:03.734: //176023/D25047000000/CCAPI/cc_api_event_indication:
   Event=162, Call Id=176023
Feb 19 17:21:03.734: //176023/D25047000000/CCAPI/cc_api_call_connected:
   Interface=0x31340418, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Feb 19 17:21:03.734: //176022/D25047000000/CCAPI/ccConferenceCreate:
   (confID=0x2AFC22A8, callID1=0x2AF96, gcid=A945E877-98B811E3-897AFE89-917343ED, tag=0x0)
Feb 19 17:21:03.734: //176023/D25047000000/CCAPI/ccConferenceCreate:
   (confID=0x2AFC22A8, callID2=0x2AF97, gcid=A945E877-98B811E3-897AFE89-917343ED, tag=0x0)
   Conference Id=0x2AFC22A8, Call Id1=176022, Call Id2=176023, Tag=0x0
Feb 19 17:21:03.734: ccConferenceCreate: ret1=0, codecMask1=1, bytes1=160, negot1=0, dtmf1=6
                    ret2=0, codecMask2=1, bytes2=160, negot2=1, dtmf2=6,
                    tx_dynamic_pt1=0, rx_dynamic_pt1=0, codec_mode1=0, params_bitmap1 =0
                    tx_dynamic_pt2=0, rx_dynamic_pt2=0, codec_mode2=0, params_bitmap2 =0
   delay media to slow start case, codec negotation is not done
Feb 19 17:21:03.734: //176022/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 19 17:21:03.734: cc_api_get_xcode_stream : 4682
Feb 19 17:21:03.734: //176022/D25047000000/CCAPI/cc_api_bridge_done:
   Conference Id=0xF2EA, Source Interface=0x31340418, Source Call Id=176022,
   Destination Call Id=176023, Disposition=0x0, Tag=0x0
Feb 19 17:21:03.734: //176023/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 19 17:21:03.734: //176023/D25047000000/CCAPI/cc_api_bridge_done:
   Conference Id=0xF2EA, Source Interface=0x31340418, Source Call Id=176023,
   Destination Call Id=176022, Disposition=0x0, Tag=0x0
Feb 19 17:21:03.734: //176022/D25047000000/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0xF2EA, Destination Call Id=176023)
   Call Entry(Conference Id=0xF2EA, Destination Call Id=176022)
Feb 19 17:21:03.734: //176022/D25047000000/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xF2EA, Call Id1=176022, Call Id2=176023
Feb 19 17:21:03.738: //176023/D25047000000/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:+38923248XXX@172.25.255.164:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.126.98.37:5060;branch=z9hG4bK31F171A4E
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Feb 19 17:21:03.738: //176022/D25047000000/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
Feb 19 17:21:03.738: //176022/D25047000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 268
v=0
o=CiscoSystemsSIP-GW-UserAgent 4524 2325 IN IP4 10.2.115.15
s=SIP Call
c=IN IP4 10.2.115.15
t=0 0
m=audio 28154 RTP/AVP 0 101 19
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Feb 19 17:21:03.750: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0038923248XXX@10.2.115.15:5060 SIP/2.0
Via: SIP/2.0/UDP 10.2.115.5:5060;branch=z9hG4bK4cce29f57702
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 233
v=0
o=CiscoSystemsCCM-SIP 659027 1 IN IP4 10.2.115.5
s=SIP Call
c=IN IP4 10.2.52.17
b=TIAS:64000
b=AS:64
t=0 0
m=audio 16388 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
Feb 19 17:21:03.754: //176022/D25047000000/CCAPI/cc_api_caps_ind:
   Destination Interface=0x31340418, Destination Call Id=176023, Source Call Id=176022,
Feb 19 17:21:03.754: //176023/D25047000000/CCAPI/cc_api_caps_ack:
   Destination Interface=0x31340418, Destination Call Id=176022, Source Call Id=176023,
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1)
Feb 19 17:21:03.754: //176022/D25047000000/CCAPI/cc_api_event_indication:
   Event=162, Call Id=176022
Feb 19 17:21:14.410: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:0038923248XXX@10.2.115.15:5060 SIP/2.0
Via: SIP/2.0/UDP 10.2.115.5:5060;branch=z9hG4bK4cce43ae98389
Max-Forwards: 70
CSeq: 102 BYE
Reason: Q.850;cause=16
Content-Length: 0
Feb 19 17:21:14.410: //176023/D25047000000/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Sum Network, Params=0x0, Call Id=176023
Feb 19 17:21:14.410: //176022/D25047000000/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x31340418, Call Id=176022
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Feb 19 17:21:14.410: //176022/D25047000000/CCAPI/ccConferenceDestroy:
   Conference Id=0xF2EA, Tag=0x0
Feb 19 17:21:14.410: //176022/D25047000000/CCAPI/cc_api_bridge_drop_done:
Feb 19 17:21:14.410: //176023/D25047000000/CCAPI/cc_api_bridge_drop_done:
Feb 19 17:21:14.410: //176022/D25047000000/CCAPI/cc_generic_bridge_done:
Feb 19 17:21:14.410: //176022/D25047000000/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Feb 19 17:21:14.414: //176022/D25047000000/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Feb 19 17:21:14.414: //176023/D25047000000/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Feb 19 17:21:14.414: //176022/D25047000000/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x31340418, Tag=0x0, Call Id=176022,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Feb 19 17:21:14.414: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 19 17:21:14.414: :cc_free_feature_vsa freeing 31B40630
Feb 19 17:21:14.414:  vsacount in free is 1
Feb 19 17:21:14.414: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 19 Feb 2014 16:21:14 gmt
CSeq: 102 BYE
Content-Length: 0
Feb 19 17:21:14.414: //176023/D25047000000/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:+38923248XXX@172.25.255.164:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.126.98.37:5060;branch=z9hG4bK31F187D0
Max-Forwards: 70
Timestamp: 1392826874
CSeq: 102 BYE
Content-Length: 0
Feb 19 17:21:14.426: //176023/D25047000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
Feb 19 17:21:14.426: //176023/D25047000000/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x31340418, Tag=0x0, Call Id=176023,
Feb 19 17:21:14.426: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 19 17:21:14.426: :cc_free_feature_vsa freeing 31B40710
Feb 19 17:21:14.426:  vsacount in free is 0
Feb 19 17:21:14.426: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
   data = 2B00079C
Feb 19 17:21:14.426: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(2AFD4B64)=0 - mempool
Debug output from "debug voip rtp session named-event"
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.02.19 17:29:25 =~=~=~=~=~=~=~=~=~=~=~=
Feb 19 17:31:52.030:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0x79 timestamp 0x4BA0
Feb 19 17:31:52.030:  << Pt:101    Evt:2       Pkt:0A 00 00
Feb 19 17:31:52.030:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0x79 timestamp 0x4BA0
Feb 19 17:31:52.030:          Pt:101    Evt:2       Pkt:0A 00 00  >>
Feb 19 17:31:52.042:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0x7B timestamp 0x4BA0
Feb 19 17:31:52.042:  << Pt:101    Evt:2       Pkt:0A 00 A0
Feb 19 17:31:52.042:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0x7B timestamp 0x4BA0
Feb 19 17:31:52.042:          Pt:101    Evt:2       Pkt:0A 00 A0  >>
Feb 19 17:31:52.050:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0x7C timestamp 0x4BA0
Feb 19 17:31:52.050:  << Pt:101    Evt:2       Pkt:0A 01 40
Feb 19 17:31:52.050:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0x7C timestamp 0x4BA0
Feb 19 17:31:52.050:          Pt:101    Evt:2       Pkt:0A 01 40  >>
Feb 19 17:31:52.062:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0x7E timestamp 0x4BA0
Feb 19 17:31:52.062:  << Pt:101    Evt:2       Pkt:0A 01 E0
Feb 19 17:31:52.062:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0x7E timestamp 0x4BA0
Feb 19 17:31:52.062:          Pt:101    Evt:2       Pkt:0A 01 E0  >>
Feb 19 17:31:52.070:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0x7F timestamp 0x4BA0
Feb 19 17:31:52.070:  << Pt:101    Evt:2       Pkt:0A 02 80
Feb 19 17:31:52.070:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0x7F timestamp 0x4BA0
Feb 19 17:31:52.070:          Pt:101    Evt:2       Pkt:0A 02 80  >>
Feb 19 17:31:52.082:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0x81 timestamp 0x4BA0
Feb 19 17:31:52.082:  << Pt:101    Evt:2       Pkt:0A 03 20
Feb 19 17:31:52.082:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0x81 timestamp 0x4BA0
Feb 19 17:31:52.082:          Pt:101    Evt:2       Pkt:0A 03 20  >>
Feb 19 17:31:52.090:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0x82 timestamp 0x4BA0
Feb 19 17:31:52.090:  << Pt:101    Evt:2       Pkt:0A 03 C0
Feb 19 17:31:52.090:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0x82 timestamp 0x4BA0
Feb 19 17:31:52.090:          Pt:101    Evt:2       Pkt:0A 03 C0  >>
Feb 19 17:31:52.102:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0x84 timestamp 0x4BA0
Feb 19 17:31:52.102:  << Pt:101    Evt:2       Pkt:0A 04 60
Feb 19 17:31:52.102:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0x84 timestamp 0x4BA0
Feb 19 17:31:52.102:          Pt:101    Evt:2       Pkt:0A 04 60  >>
Feb 19 17:31:52.110:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0x85 timestamp 0x4BA0
Feb 19 17:31:52.110:  << Pt:101    Evt:2       Pkt:0A 05 00
Feb 19 17:31:52.110:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0x85 timestamp 0x4BA0
Feb 19 17:31:52.110:          Pt:101    Evt:2       Pkt:0A 05 00  >>
Feb 19 17:31:52.122:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0x87 timestamp 0x4BA0
Feb 19 17:31:52.122:  << Pt:101    Evt:2       Pkt:0A 05 A0
Feb 19 17:31:52.122:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0x87 timestamp 0x4BA0
Feb 19 17:31:52.122:          Pt:101    Evt:2       Pkt:0A 05 A0  >>
Feb 19 17:31:52.130:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0x88 timestamp 0x4BA0
Feb 19 17:31:52.130:  << Pt:101    Evt:2       Pkt:0A 06 40
Feb 19 17:31:52.130:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0x88 timestamp 0x4BA0
Feb 19 17:31:52.130:          Pt:101    Evt:2       Pkt:0A 06 40  >>
Feb 19 17:31:52.142:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0x8A timestamp 0x4BA0
Feb 19 17:31:52.142:  << Pt:101    Evt:2       Pkt:0A 06 E0
Feb 19 17:31:52.142:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0x8A timestamp 0x4BA0
Feb 19 17:31:52.142:          Pt:101    Evt:2       Pkt:0A 06 E0  >>
Feb 19 17:31:52.150:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0x8B timestamp 0x4BA0
Feb 19 17:31:52.150:  << Pt:101    Evt:2       Pkt:0A 07 80
Feb 19 17:31:52.150:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0x8B timestamp 0x4BA0
Feb 19 17:31:52.150:          Pt:101    Evt:2       Pkt:0A 07 80  >>
Feb 19 17:31:52.162:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0x8D timestamp 0x4BA0
Feb 19 17:31:52.162:  << Pt:101    Evt:2       Pkt:0A 08 20
Feb 19 17:31:52.162:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0x8D timestamp 0x4BA0
Feb 19 17:31:52.162:          Pt:101    Evt:2       Pkt:0A 08 20  >>
Feb 19 17:31:52.170:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0x8E timestamp 0x4BA0
Feb 19 17:31:52.170:  << Pt:101    Evt:2       Pkt:0A 08 C0
Feb 19 17:31:52.170:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0x8E timestamp 0x4BA0
Feb 19 17:31:52.170:          Pt:101    Evt:2       Pkt:0A 08 C0  >>
Feb 19 17:31:52.182:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0x90 timestamp 0x4BA0
Feb 19 17:31:52.182:  << Pt:101    Evt:2       Pkt:0A 09 60
Feb 19 17:31:52.182:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0x90 timestamp 0x4BA0
Feb 19 17:31:52.182:          Pt:101    Evt:2       Pkt:0A 09 60  >>
Feb 19 17:31:52.190:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0x91 timestamp 0x4BA0
Feb 19 17:31:52.190:  << Pt:101    Evt:2       Pkt:0A 0A 00
Feb 19 17:31:52.190:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0x91 timestamp 0x4BA0
Feb 19 17:31:52.190:          Pt:101    Evt:2       Pkt:0A 0A 00  >>
Feb 19 17:31:52.202:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0x93 timestamp 0x4BA0
Feb 19 17:31:52.202:  << Pt:101    Evt:2       Pkt:8A 0A A0
Feb 19 17:31:52.202:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0x93 timestamp 0x4BA0
Feb 19 17:31:52.202:          Pt:101    Evt:2       Pkt:8A 0A A0  >>
Feb 19 17:31:52.202:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0x94 timestamp 0x4BA0
Feb 19 17:31:52.202:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0x94 timestamp 0x4BA0
Feb 19 17:31:52.218:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0x95 timestamp 0x4BA0
Feb 19 17:31:52.218:  << Pt:101    Evt:2       Pkt:8A 0A A0
Feb 19 17:31:52.218:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0x95 timestamp 0x4BA0
Feb 19 17:31:52.218:          Pt:101    Evt:2       Pkt:8A 0A A0  >>
Feb 19 17:31:52.542:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xA6 timestamp 0x5B40
Feb 19 17:31:52.542:  << Pt:101    Evt:3       Pkt:0A 00 00
Feb 19 17:31:52.542:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xA6 timestamp 0x5B40
Feb 19 17:31:52.542:          Pt:101    Evt:3       Pkt:0A 00 00  >>
Feb 19 17:31:52.550:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xA7 timestamp 0x5B40
Feb 19 17:31:52.550:  << Pt:101    Evt:3       Pkt:0A 00 A0
Feb 19 17:31:52.550:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xA7 timestamp 0x5B40
Feb 19 17:31:52.550:          Pt:101    Evt:3       Pkt:0A 00 A0  >>
Feb 19 17:31:52.562:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xA9 timestamp 0x5B40
Feb 19 17:31:52.562:  << Pt:101    Evt:3       Pkt:0A 01 40
Feb 19 17:31:52.562:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xA9 timestamp 0x5B40
Feb 19 17:31:52.562:          Pt:101    Evt:3       Pkt:0A 01 40  >>
Feb 19 17:31:52.570:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xAA timestamp 0x5B40
Feb 19 17:31:52.570:  << Pt:101    Evt:3       Pkt:0A 01 E0
Feb 19 17:31:52.570:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xAA timestamp 0x5B40
Feb 19 17:31:52.570:          Pt:101    Evt:3       Pkt:0A 01 E0  >>
Feb 19 17:31:52.582:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xAC timestamp 0x5B40
Feb 19 17:31:52.582:  << Pt:101    Evt:3       Pkt:0A 02 80
Feb 19 17:31:52.582:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xAC timestamp 0x5B40
Feb 19 17:31:52.582:          Pt:101    Evt:3       Pkt:0A 02 80  >>
Feb 19 17:31:52.590:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xAD timestamp 0x5B40
Feb 19 17:31:52.590:  << Pt:101    Evt:3       Pkt:0A 03 20
Feb 19 17:31:52.590:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xAD timestamp 0x5B40
Feb 19 17:31:52.590:          Pt:101    Evt:3       Pkt:0A 03 20  >>
Feb 19 17:31:52.602:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xAF timestamp 0x5B40
Feb 19 17:31:52.602:  << Pt:101    Evt:3       Pkt:0A 03 C0
Feb 19 17:31:52.602:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xAF timestamp 0x5B40
Feb 19 17:31:52.602:          Pt:101    Evt:3       Pkt:0A 03 C0  >>
Feb 19 17:31:52.610:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xB0 timestamp 0x5B40
Feb 19 17:31:52.610:  << Pt:101    Evt:3       Pkt:0A 04 60
Feb 19 17:31:52.610:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xB0 timestamp 0x5B40
Feb 19 17:31:52.610:          Pt:101    Evt:3       Pkt:0A 04 60  >>
Feb 19 17:31:52.622:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xB2 timestamp 0x5B40
Feb 19 17:31:52.622:  << Pt:101    Evt:3       Pkt:0A 05 00
Feb 19 17:31:52.622:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xB2 timestamp 0x5B40
Feb 19 17:31:52.622:          Pt:101    Evt:3       Pkt:0A 05 00  >>
Feb 19 17:31:52.630:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xB3 timestamp 0x5B40
Feb 19 17:31:52.630:  << Pt:101    Evt:3       Pkt:0A 05 A0
Feb 19 17:31:52.630:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xB3 timestamp 0x5B40
Feb 19 17:31:52.630:          Pt:101    Evt:3       Pkt:0A 05 A0  >>
Feb 19 17:31:52.642:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xB5 timestamp 0x5B40
Feb 19 17:31:52.642:  << Pt:101    Evt:3       Pkt:0A 06 40
Feb 19 17:31:52.642:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xB5 timestamp 0x5B40
Feb 19 17:31:52.642:          Pt:101    Evt:3       Pkt:0A 06 40  >>
Feb 19 17:31:52.650:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xB6 timestamp 0x5B40
Feb 19 17:31:52.650:  << Pt:101    Evt:3       Pkt:0A 06 E0
Feb 19 17:31:52.650:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xB6 timestamp 0x5B40
Feb 19 17:31:52.650:          Pt:101    Evt:3       Pkt:0A 06 E0  >>
Feb 19 17:31:52.662:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xB8 timestamp 0x5B40
Feb 19 17:31:52.662:  << Pt:101    Evt:3       Pkt:8A 07 80
Feb 19 17:31:52.662:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xB8 timestamp 0x5B40
Feb 19 17:31:52.662:          Pt:101    Evt:3       Pkt:8A 07 80  >>
Feb 19 17:31:52.662:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xB9 timestamp 0x5B40
Feb 19 17:31:52.662:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xB9 timestamp 0x5B40
Feb 19 17:31:52.678:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xBA timestamp 0x5B40
Feb 19 17:31:52.678:  << Pt:101    Evt:3       Pkt:8A 07 80
Feb 19 17:31:52.678:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xBA timestamp 0x5B40
Feb 19 17:31:52.678:          Pt:101    Evt:3       Pkt:8A 07 80  >>
Feb 19 17:31:52.970:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xC9 timestamp 0x67C0
Feb 19 17:31:52.970:  << Pt:101    Evt:5       Pkt:0A 00 00
Feb 19 17:31:52.970:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xC9 timestamp 0x67C0
Feb 19 17:31:52.970:          Pt:101    Evt:5       Pkt:0A 00 00  >>
Feb 19 17:31:52.982:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xCA timestamp 0x67C0
Feb 19 17:31:52.982:  << Pt:101    Evt:5       Pkt:0A 00 A0
Feb 19 17:31:52.982:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xCA timestamp 0x67C0
Feb 19 17:31:52.982:          Pt:101    Evt:5       Pkt:0A 00 A0  >>
Feb 19 17:31:52.990:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xCC timestamp 0x67C0
Feb 19 17:31:52.990:  << Pt:101    Evt:5       Pkt:0A 01 40
Feb 19 17:31:52.990:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xCC timestamp 0x67C0
Feb 19 17:31:52.990:          Pt:101    Evt:5       Pkt:0A 01 40  >>
Feb 19 17:31:53.002:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xCD timestamp 0x67C0
Feb 19 17:31:53.002:  << Pt:101    Evt:5       Pkt:0A 01 E0
Feb 19 17:31:53.002:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xCD timestamp 0x67C0
Feb 19 17:31:53.002:          Pt:101    Evt:5       Pkt:0A 01 E0  >>
Feb 19 17:31:53.010:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xCF timestamp 0x67C0
Feb 19 17:31:53.010:  << Pt:101    Evt:5       Pkt:0A 02 80
Feb 19 17:31:53.010:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xCF timestamp 0x67C0
Feb 19 17:31:53.010:          Pt:101    Evt:5       Pkt:0A 02 80  >>
Feb 19 17:31:53.022:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xD0 timestamp 0x67C0
Feb 19 17:31:53.022:  << Pt:101    Evt:5       Pkt:0A 03 20
Feb 19 17:31:53.022:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xD0 timestamp 0x67C0
Feb 19 17:31:53.022:          Pt:101    Evt:5       Pkt:0A 03 20  >>
Feb 19 17:31:53.030:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xD2 timestamp 0x67C0
Feb 19 17:31:53.030:  << Pt:101    Evt:5       Pkt:0A 03 C0
Feb 19 17:31:53.030:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xD2 timestamp 0x67C0
Feb 19 17:31:53.030:          Pt:101    Evt:5       Pkt:0A 03 C0  >>
Feb 19 17:31:53.042:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xD3 timestamp 0x67C0
Feb 19 17:31:53.042:  << Pt:101    Evt:5       Pkt:0A 04 60
Feb 19 17:31:53.042:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xD3 timestamp 0x67C0
Feb 19 17:31:53.042:          Pt:101    Evt:5       Pkt:0A 04 60  >>
Feb 19 17:31:53.050:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xD5 timestamp 0x67C0
Feb 19 17:31:53.050:  << Pt:101    Evt:5       Pkt:0A 05 00
Feb 19 17:31:53.050:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xD5 timestamp 0x67C0
Feb 19 17:31:53.050:          Pt:101    Evt:5       Pkt:0A 05 00  >>
Feb 19 17:31:53.062:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xD6 timestamp 0x67C0
Feb 19 17:31:53.062:  << Pt:101    Evt:5       Pkt:0A 05 A0
Feb 19 17:31:53.062:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xD6 timestamp 0x67C0
Feb 19 17:31:53.062:          Pt:101    Evt:5       Pkt:0A 05 A0  >>
Feb 19 17:31:53.070:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xD8 timestamp 0x67C0
Feb 19 17:31:53.070:  << Pt:101    Evt:5       Pkt:0A 06 40
Feb 19 17:31:53.070:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xD8 timestamp 0x67C0
Feb 19 17:31:53.070:          Pt:101    Evt:5       Pkt:0A 06 40  >>
Feb 19 17:31:53.082:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xD9 timestamp 0x67C0
Feb 19 17:31:53.082:  << Pt:101    Evt:5       Pkt:0A 06 E0
Feb 19 17:31:53.082:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xD9 timestamp 0x67C0
Feb 19 17:31:53.082:          Pt:101    Evt:5       Pkt:0A 06 E0  >>
Feb 19 17:31:53.090:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xDB timestamp 0x67C0
Feb 19 17:31:53.090:  << Pt:101    Evt:5       Pkt:0A 07 80
Feb 19 17:31:53.090:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xDB timestamp 0x67C0
Feb 19 17:31:53.090:          Pt:101    Evt:5       Pkt:0A 07 80  >>
Feb 19 17:31:53.102:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xDC timestamp 0x67C0
Feb 19 17:31:53.102:  << Pt:101    Evt:5       Pkt:8A 08 20
Feb 19 17:31:53.102:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xDC timestamp 0x67C0
Feb 19 17:31:53.102:          Pt:101    Evt:5       Pkt:8A 08 20  >>
Feb 19 17:31:53.102:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xDD timestamp 0x67C0
Feb 19 17:31:53.102:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xDD timestamp 0x67C0
Feb 19 17:31:53.118:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xDE timestamp 0x67C0
Feb 19 17:31:53.118:  << Pt:101    Evt:5       Pkt:8A 08 20
Feb 19 17:31:53.118:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xDE timestamp 0x67C0
Feb 19 17:31:53.118:          Pt:101    Evt:5       Pkt:8A 08 20  >>
Feb 19 17:31:53.270:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xE7 timestamp 0x7080
Feb 19 17:31:53.270:  << Pt:101    Evt:2       Pkt:0A 00 00
Feb 19 17:31:53.270:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xE7 timestamp 0x7080
Feb 19 17:31:53.270:          Pt:101    Evt:2       Pkt:0A 00 00  >>
Feb 19 17:31:53.282:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xE8 timestamp 0x7080
Feb 19 17:31:53.282:  << Pt:101    Evt:2       Pkt:0A 00 A0
Feb 19 17:31:53.282:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xE8 timestamp 0x7080
Feb 19 17:31:53.282:          Pt:101    Evt:2       Pkt:0A 00 A0  >>
Feb 19 17:31:53.290:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xEA timestamp 0x7080
Feb 19 17:31:53.290:  << Pt:101    Evt:2       Pkt:0A 01 40
Feb 19 17:31:53.290:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xEA timestamp 0x7080
Feb 19 17:31:53.290:          Pt:101    Evt:2       Pkt:0A 01 40  >>
Feb 19 17:31:53.302:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xEB timestamp 0x7080
Feb 19 17:31:53.302:  << Pt:101    Evt:2       Pkt:0A 01 E0
Feb 19 17:31:53.302:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xEB timestamp 0x7080
Feb 19 17:31:53.302:          Pt:101    Evt:2       Pkt:0A 01 E0  >>
Feb 19 17:31:53.310:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xED timestamp 0x7080
Feb 19 17:31:53.310:  << Pt:101    Evt:2       Pkt:0A 02 80
Feb 19 17:31:53.310:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xED timestamp 0x7080
Feb 19 17:31:53.310:          Pt:101    Evt:2       Pkt:0A 02 80  >>
Feb 19 17:31:53.322:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xEE timestamp 0x7080
Feb 19 17:31:53.322:  << Pt:101    Evt:2       Pkt:0A 03 20
Feb 19 17:31:53.322:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xEE timestamp 0x7080
Feb 19 17:31:53.322:          Pt:101    Evt:2       Pkt:0A 03 20  >>
Feb 19 17:31:53.330:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xF0 timestamp 0x7080
Feb 19 17:31:53.330:  << Pt:101    Evt:2       Pkt:0A 03 C0
Feb 19 17:31:53.330:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xF0 timestamp 0x7080
Feb 19 17:31:53.330:          Pt:101    Evt:2       Pkt:0A 03 C0  >>
Feb 19 17:31:53.342:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xF1 timestamp 0x7080
Feb 19 17:31:53.342:  << Pt:101    Evt:2       Pkt:0A 04 60
Feb 19 17:31:53.342:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xF1 timestamp 0x7080
Feb 19 17:31:53.342:          Pt:101    Evt:2       Pkt:0A 04 60  >>
Feb 19 17:31:53.350:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xF3 timestamp 0x7080
Feb 19 17:31:53.350:  << Pt:101    Evt:2       Pkt:0A 05 00
Feb 19 17:31:53.350:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xF3 timestamp 0x7080
Feb 19 17:31:53.350:          Pt:101    Evt:2       Pkt:0A 05 00  >>
Feb 19 17:31:53.362:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xF4 timestamp 0x7080
Feb 19 17:31:53.362:  << Pt:101    Evt:2       Pkt:0A 05 A0
Feb 19 17:31:53.362:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xF4 timestamp 0x7080
Feb 19 17:31:53.362:          Pt:101    Evt:2       Pkt:0A 05 A0  >>
Feb 19 17:31:53.370:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xF6 timestamp 0x7080
Feb 19 17:31:53.370:  << Pt:101    Evt:2       Pkt:0A 06 40
Feb 19 17:31:53.370:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xF6 timestamp 0x7080
Feb 19 17:31:53.370:          Pt:101    Evt:2       Pkt:0A 06 40  >>
Feb 19 17:31:53.382:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xF7 timestamp 0x7080
Feb 19 17:31:53.382:  << Pt:101    Evt:2       Pkt:0A 06 E0
Feb 19 17:31:53.382:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xF7 timestamp 0x7080
Feb 19 17:31:53.382:          Pt:101    Evt:2       Pkt:0A 06 E0  >>
Feb 19 17:31:53.390:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xF9 timestamp 0x7080
Feb 19 17:31:53.390:  << Pt:101    Evt:2       Pkt:0A 07 80
Feb 19 17:31:53.390:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xF9 timestamp 0x7080
Feb 19 17:31:53.390:          Pt:101    Evt:2       Pkt:0A 07 80  >>
Feb 19 17:31:53.402:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xFA timestamp 0x7080
Feb 19 17:31:53.402:  << Pt:101    Evt:2       Pkt:0A 08 20
Feb 19 17:31:53.402:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xFA timestamp 0x7080
Feb 19 17:31:53.402:          Pt:101    Evt:2       Pkt:0A 08 20  >>
Feb 19 17:31:53.410:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xFC timestamp 0x7080
Feb 19 17:31:53.410:  << Pt:101    Evt:2       Pkt:0A 08 C0
Feb 19 17:31:53.410:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xFC timestamp 0x7080
Feb 19 17:31:53.410:          Pt:101    Evt:2       Pkt:0A 08 C0  >>
Feb 19 17:31:53.422:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xFD timestamp 0x7080
Feb 19 17:31:53.422:  << Pt:101    Evt:2       Pkt:8A 09 60
Feb 19 17:31:53.422:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xFD timestamp 0x7080
Feb 19 17:31:53.422:          Pt:101    Evt:2       Pkt:8A 09 60  >>
Feb 19 17:31:53.422:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xFE timestamp 0x7080
Feb 19 17:31:53.422:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xFE timestamp 0x7080
Feb 19 17:31:53.438:          s=VoIP d=DSP payload 0x65 ssrc 0x58F0F00A sequence 0xFF timestamp 0x7080
Feb 19 17:31:53.438:  << Pt:101    Evt:2       Pkt:8A 09 60
Feb 19 17:31:53.438:          s=DSP d=VoIP payload 0x65 ssrc 0x58F0F00A sequence 0xFF timestamp 0x7080
Feb 19 17:31:53.438:          Pt:101    Evt:2       Pkt:8A 09 60  >>
This trace shows that the DTMF negotiation is using rtp-nte. Pt=101 and you can see the dtmf events in the RTP stream using payload 101.
On your sip messaging as well you can see that your provider
This is advertised on your CUBE
a=fmtp:101 0-15
This is advertised by the ITSP
a=fmtp:18 annexb=no
a=fmtp:101 0-15
This clearly shows that they both negotiate rtp-nte...So I am at a loss as to why you say it doesnt work when you configure rtp-nte, because this is what is negotiated
Nevertheless, thank You!
Content for Community-Ad
Spotlight Awards 2021
