05-28-2015 06:36 AM - edited 03-17-2019 03:09 AM
Hi, I am seeing "Call not end-to-end ISDN, may have in-band info" during a debug isdn q931 on a failed call. Can someone tell me what it means? As far as I can tell, it's only happenind to a specific number dialed. All other numbers dialed using same dial-peer does not have this problem. csim debug below. Wondering if this is a telco issue? Thank you.
V_OUTREACH_C2911_1#term mon
V_OUTREACH_C2911_1#debug isdn q931
debug isdn q931 is ON.
V_OUTREACH_C2911_1#csim start 9xxxxxxxxxx
csim: called number = 9xxxxxxxxxx, loop count = 1 ping count = 0
001171: May 28 09:25:43.137 edt: ISDN Se0/0/0:23 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 13
001172: May 28 09:25:43.137 edt: ISDN Se0/0/0:23 Q931: Sending SETUP callref = 0x18DC callID = 0x985D switch = primary-ni interface = User
001173: May 28 09:25:43.137 edt: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x18DC
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98396
Exclusive, Channel 22
Called Party Number i = 0xA1, 'xxxxxxxxxx'
Plan:ISDN, Type:National
001174: May 28 09:25:43.225 edt: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x98DC
001175: May 28 09:25:43.665 edt: ISDN Se0/0/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x98DC
Cause i = 0x829F - Normal, unspecified
Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
001176: May 28 09:25:44.069 edt: ISDN Se0/0/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x98DC
Progress Ind i = 0x8288 - In-band info or appropriate now available
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
V_OUTREACH_C2911_1#
001177: May 28 09:26:04.097 edt: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x18DC
Cause i = 0x8090 - Normal call clearing
001178: May 28 09:26:04.117 edt: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x98DC
001179: May 28 09:26:04.117 edt: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x18DC
V_OUTREACH_C2911_1#u all
05-28-2015 05:06 PM
Just make sure you are sending the correct digits to telco, Telco may be expecting an area code etc. But if you can dial other numbers in the same region successfully, try if you call that specific number from your mobile and if you can pretty much should be a Telco issue.
-Terry
06-01-2015 06:15 AM
Thank you Terry, I am able to call other numbers on the same exchange. I will follow up with the telco.
