What features do not work when Publisher is down?
jamize
Beginner
Beginner
                   We are planning on upgrading to 8.6(2) and according to the documentation it takes 2-3 hours per server.  We would like to know what features will be down while the publisher is down during the upgrade.
Jeff Mize
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Yes
java
if this helps, please rate
8 Replies 8
Jaime Valencia
BAT, and any kind of admin changes will be down, only UFF will work.
Depending on if you have EM and other services with redundancy or not, they might not work.
java
