05-09-2013 04:20 PM - edited 03-16-2019 05:15 PM
Hi Cisco techs,
After all the reading I have done on this topic.
The one issue that isnt conclusive is whether to install CME first on the router or install firmware/software for phones first?
Or doesnt this matter?
Solved! Go to Solution.
05-09-2013 05:38 PM
You install the call control agent CME/CUCM, configure the phones, and then plug them so they register and download the FW/configuration.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
05-09-2013 05:38 PM
java
05-09-2013 08:14 PM
Hi Mr Valencia,
Thanks for your reply.
When I go to install a 70mb CME via tftp32..router displays permission denied. after issuing command..
archive /xtract tftp://ipadress/filename.tar flash:
Logged in using admin level 15 on router
Any ideas please?
05-13-2013 05:57 PM
Thanks Mr Valencia for that.
One more question if I can please?
archive tar /xtract tftp://ipadress/filename.tar flash:
Do you have exposure to the above please?
05-09-2013 07:25 PM
In fact, phones come with a factory preinstalled firmware. So, as Jaime said, you install/configure CME, plug the phones and they will work.
Later, if you wish, you can install the latest firmware in CME and upgrade the phones.
- Adrian.
05-14-2013 08:53 AM
It looks incorrect login details, try to reset the login details or create a new account on the tftp and try again.
05-14-2013 08:38 PM
Will try 2nite and let u know..thanks again..:)
05-14-2013 08:57 PM
Also. Do access control lists need to be updated/created for this?
