What gets installed first..CME or cisco IP phones
John Cheetley
Level 8
Level 8
Hi Cisco techs,
After all the reading I have done on this topic.
The one issue that isnt conclusive is whether to install CME first on the router or install firmware/software for phones first?
Or doesnt this matter?
Jaime Valencia
You install the call control agent CME/CUCM, configure the phones, and then plug them so they register and download the FW/configuration.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
7 Replies 7
Jaime Valencia
java
java
Hi Mr Valencia,
Thanks for your reply.
When I go to install a 70mb CME via tftp32..router displays permission denied. after issuing command..
archive /xtract tftp://ipadress/filename.tar flash:
Logged in using admin level 15 on router
Any ideas please?
Thanks Mr Valencia for that.
One more question if I can please?
archive tar /xtract tftp://ipadress/filename.tar flash:
Do you have exposure to the above please?
Adrian Saavedra
Level 11
Level 11
In fact, phones come with a factory preinstalled firmware. So, as Jaime said, you install/configure CME, plug the phones and they will work.
Later, if you wish, you can install the latest firmware in CME and upgrade the phones.
- Adrian.
    It looks incorrect login details, try to reset the login details or create a new account  on the tftp and try again.
Will try 2nite and let u know..thanks again..:)
Also. Do access control lists need to be updated/created for this?
