What is a Best Remote Control Cisco IP Phones Software For CCIE Voice Lab
gujiguy2642
Beginner
Beginner
I have built my lab at work and i am trying to figure out a way to use it while i am at home. Although i can access all the servers, routers and switches, i am unable to use the phone to make and recieve calls.
I have tried to use a unified FX Phone VIew Software but keep running into issue and have been unsucessful in using it and more over i do not like the interface for it.
Wanted to find out what others were using ?
Thanks for yoru help and support !!!
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Use CIPC as remote endpoint.
Chris Deren
Hall of Fame Master
You could also run Jabber as Phone (No need for CUPS or IMP server), or run x-lite SIP phone:
http://www.counterpath.com/x-lite.html
IPBlue is another company re-selling softphone, and there are others out there.
HTH,
Chris
Recognize Your Peers
