ā01-01-2016 06:31 PM - edited ā03-17-2019 05:22 AM
The below configurations can work for the two routers(RbāR1) connected with each other. But when the same configuration are used between two router( RbāR2), these commands can not work, which means output of the commands (show isdn status) shows āState = TEI_ASSIGNEDā There are different protocols for the configuration though the main commands are same. I would like to know the minimum requirement for configuring isdn for two routers.
I think, the below configuration is minimum configuration for isdn between two router(2811). If I am wrong, can you correct these commands? How do you think about the configuration? Thank you.
network-clock-participate wic 0
network-clock-select 1 t1 0/0/0
controller t1 0/0/0
pri-group timeslots 1-24
no shut
interface Serial0/0/0:23
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn protocol-emulate network (or user)
Solved! Go to Solution.
ā01-01-2016 08:43 PM
these are the basic configuration for you to make it work also you need to a T1 Cable connected to T1 Controller . Here layer 3 controlled by CUCM hence you need to add those command to make it work.
controller T1 x/y/z
pri-group timeslots 1-24 service mgcp
no ip address
encapsulation hdlc
isdn outgoing display-ie
isdn outgoing ie redirecting-number
no cdp enable
ccm-manager redundant-host y.y.y.y ==========This command needed when you have redundancy
ccm-manager mgcp
ccm-manager music-on-hold
mgcp
mgcp call-agent X.x.x.x service-type mgcp version 0.1
https://supportforums.cisco.com/document/90521/mgcp-gateway-integration-cucm-and-pstn-service-provider
Please also refer to above doc as well.
Br,
Nadeem Ahmed
Ps: Please rate all useful post
ā01-01-2016 07:27 PM
If that's supposed to be MGCP, you're missing things, there are plenty of examples on cisco.com, CSC, and I also have one in my FAQ, there's no shortage of examples if you search.
and also, do you have a crossover cable already connected??????
ā01-01-2016 07:52 PM
Thank you for your reply. You are right. If it is for mgcp, we should add service mgcp behind timeslot 1-24. I made the RJ48. It can work
controller T1 x/y/z
no ip address
encapsulation hdlc
no cdp enable
ccm-manager mgcp
mgcp
Br,
Nadeem Ahmed
ā01-01-2016 09:19 PM
Thank you so much for your good reply and the link as well.
One more thing that I am still confused. Can we say without gateway configuration, the two routers also can establish the normal isdn connection? that means the router can show "State = MULTIPLE_FRAME_ESTABLISHED" when using show isdn status
ā01-01-2016 09:32 PM
Layer 3 controlled by CUCM hence you required mgcp command in order established
Rajeev
ā01-01-2016 09:37 PM
When you Gateway is controlled as MGCP by CUCM then you need to put those command where layer 3 back-hauled/controlled by CUCM .
Secondly when your Gateway is SIP/H.323 then you just need put below command to make ISDN works ie Multiframe established.
controller 0/0/0
pri-group timeslot 1-24
no ip address
encapsulation hdlc
isdn bind-l3 ccm-manager ==============you don't need this command when its not mgcp.
no cdp enable
above configuration mere required between two router/Gateway/CME end to end PRI ISDN connection to work.
Br,
Nadeem Ahmed
PS: Please rate all useful post.
ā01-02-2016 09:30 AM
Do you think that without gateway configuration(mgcp, h323 or sip), the isdn can work wellļ¼with "State = MULTIPLE_FRAME_ESTABLISHED"ļ¼? Thanks
ā01-02-2016 10:08 AM
It should not, as ISDN is just a telephone line that provides two primary channels for communication, you should have the BRI configuration necessary for the router to communicate with the Telco ISDN switch. and you perform bri configuration on a router/gateway to establish connection to your telco. and these are isdn states which can be seen from gateways/routers only if configured properly. refer below docs for more on the same.
http://www.cisco.com/c/en/us/support/docs/dial-access/integrated-services-digital-networks-isdn-channel-associated-signaling-cas/5705-bri-sh-isdn-stat.html
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/srnd/design/guide/cmesrnd/gatewy.html
ā01-02-2016 12:54 PM
Thank you. I agree
ā01-02-2016 12:53 PM
controller 0/0/0
no ip address
encapsulation hdlc
no cdp enableabove configuration mere required between two router/Gateway/CME end to end PRI ISDN connection to work.
These above commands do not include the command:
without the command, I cannot have the isdn work well between the two routers when using show isdn status. Do I miss something?
