ā06-02-2010 01:55 AM - edited ā03-15-2019 11:03 PM
when call cme from sip trunk and hangup the call from the calling phone debug ccsip show :
Jun 2 08:52:40.541: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Jun 2 08:52:40.541: //-1/xxxxxxxxxxxx/SIP/Error/sipSPISipIncomingMsg: Invalid method for (STATE_IDLE): CANCEL
Jun 2 08:52:40.545: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPISendErrorRespNoCCB: Sending Error Response No CCB to the transport layer
Jun 2 08:52:40.545: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPITransportSendMessage: msg=0x88D771A0, addr=172.19.1.78, port=5060, sentBy_port=5060, is_req=0, transport=1, switch=0, callBack=0x00000000
Jun 2 08:52:40.545: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnectionIfExists: Connection Holder for addr=172.19.1.78 not found
CME(config-sip-ua)#
Jun 2 08:52:40.545: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x88D771A0, addr=172.19.1.78, port=5060, connId=0 for UDP
Jun 2 08:52:40.553: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 481 Call Leg/Transaction Does Not Exist
Via: SIP/2.0/UDP 77.72.169.134:5060;branch=z9hG4bK49b6543463d947caa1e4b81bf0267d24;received=172.19.1.78
From: <sip:00@sip.justvoip.com:5060>;tag=4e0113ac4c050c86452e9
To: <sip:my username@myip add:5060>
Call-ID: 4c4d940ab840442cb123a51a893cf5f5
CSeq: 3 CANCEL
Content-Length: 0
Solved! Go to Solution.
ā06-02-2010 03:00 AM
This means that the gateway does not have any record of the call. Either there wasn't any call or it has deleted the information.
Looking at the snippet, that particular msg was sent in reponse of cancel event. Without seeing the whole debug, I am assuming that GW received cancel earlier and deleted the call and send reponse. But caller side sent another cancel msg so gw gives above msg
Hope this helps
thanks
- abu
Hope this helps
thanks
- abu
ā06-02-2010 03:06 AM
ā06-02-2010 03:32 AM
You have connectivity issue. The response that the CME is sending, is not received by the caller side. That is why it kept sending.
And same happens when caller side cancels the call, GW sends response and delete from its memory, but caller proxy keep sending it, so gw sends 487 msg.
All response will be sent to 77.72.169.134. Can you check if there is anything that could drop the packet or not?
Thank you
ā06-02-2010 03:56 AM
thanks for you quick response
all i can tell you regarding connectivity that cme router has public ip address from ISP directly connected to its fa0/1
i can ping this ip address from the router
CME#ping 77.72.169.134
Sending 5, 100-byte ICMP Echos to 77.72.169.134, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 32/32/32 ms
but i can not trace route it
CME#traceroute 77.72.169.134
Tracing the route to 77.72.169.134
1 82-168-191-254.ip.telfort.nl (82.168.191.254) 16 msec 16 msec 16 msec
2 172.26.42.33 16 msec 16 msec 16 msec
3 * * *
4 195.190.227.223 20 msec 20 msec 20 msec
5 ffm-s1-rou-1022.DE.eurorings.net (134.222.229.18) 36 msec
obl-rou-1021.NL.eurorings.net (134.222.229.137) 20 msec
obl-rou-1021.NL.eurorings.net (134.222.229.129) 16 msec
6 ffm-s1-rou-1022.DE.eurorings.net (134.222.231.138) 36 msec 36 msec 36 msec
7 ffm-s1-rou-1006.DE.eurorings.net (134.222.227.10) 56 msec 52 msec *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
CME#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
C 192.168.10.0/24 is directly connected, FastEthernet0/0
82.0.0.0/32 is subnetted, 1 subnets
S 82.168.191.254 [254/0] via *my ip address*, FastEthernet0/1
S* 0.0.0.0/0 is directly connected, FastEthernet0/1
C 195.240.*.0/21 is directly connected, FastEthernet0/1
is th there any debug output you would like to see ??? kindly advice
thank you
