01-13-2015 08:18 AM - edited 03-17-2019 01:33 AM
Rather than clicking though the drop down menus in CUCM, what is the most efficient way to capture a complete configuration settings in CUCM? I know some of the settings can be done using BAT, but what about other settings like Enterprise Parameters, DHCP server/subnet, etc.? If the captured configurations are in human readable format will be even better.
Solved! Go to Solution.
01-13-2015 09:05 AM
Go to Bulk Administration -> Import/export -> Export, Give any name of the file and select required components. You will get these as CSV files and can read/analyze these.
Suresh
01-13-2015 09:05 AM
Suresh
01-13-2015 09:46 AM
01-13-2015 10:02 AM
Hi there,
Just wanted to add a reference to the great tips from my friends Aman & Suresh (+5 each)
Variphy has an excellent Configuration snapshot/change management feature that works great for these type of reports and can identify recent changes as well :)
http://www.variphy.com/products/enterprises/cisco-change-management-reporting
Cheers!
Rob
01-13-2015 10:21 PM
[+5] to Rob and Brandon for sharing more info.
Hi Brandon,
I downlaoded the latest software cipinventory-v0.11 from the site and unzipped it .I could find four files and not any exe .I have attached the snapshot.
when I click on .pl file it asks which program to be used for opening.
Am I following the correct procedure or missing something?
regds,
aman
01-13-2015 10:29 AM
One more resource since I just had to deal with getting phone info out of the CUCM.
https://sourceforge.net/projects/cipinventory/
It's free and easy to use. This program pulls phone info via the web front end and packs it nicely into a .CSV file that can be opened in excel. This only works for phones though and not the entire CUCM config but hey it's free.
