Walkthrough Wednesdays
826
angelo castro
Beginner
What is The cause i have this alert " Voicemail is disabled in cisco unity Express module"
11 REPLIES 11
Charles Hill
Rising star
Take a look at the posting below.
CUE was disabled as well.
https://supportforums.cisco.com/discussion/11358846/voicemail-disabled-unity-express-71
Hope this helps...
Please check the license status from the CLI.
One of the reason for the voice mail disabled is the license expiry or not port for voice mail.
Please paste the output for show license all, show license status application from CUE CLI
Below is the reference for the Licensing on CUE.
https://supportforums.cisco.com/document/32076/cue-licensing-faq
Raaj
There are couple of reason for voicemail disabled.
1) was it license file uploaded to CUE.
2) VMBX increases the max count limit issued to you.
3) port count exceeded.
Just log to CUE CLI
# show license status application
# show license all <check the number of VMBX and port you have and configure>
Br,
Nadeem
Br, Nadeem Please rate all useful post.
hi Nadeem
Router#show license all
License Store: Primary License Storage
StoreIndex: 0   Feature: ipbasek9                          Version: 1.0
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
StoreIndex: 1   Feature: uck9                              Version: 1.0
        License Type: Evaluation
        License State: Inactive
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 0  minute  0  second
            Period used: 8  weeks 4  days
        License Priority: Low
StoreIndex: 2   Feature: securityk9                        Version: 1.0
StoreIndex: 3   Feature: SSL_VPN                           Version: 1.0
        License State: Active, Not in Use, EULA accepted
            Evaluation period left: 8  weeks 4  days
            Period used: 0  minute  0  second
        License Count: 100/0/0  (Active/In-use/Violation)
StoreIndex: 4   Feature: gatekeeper                        Version: 1.0
StoreIndex: 5   Feature: uck9                              Version: 1.0
StoreIndex: 6   Feature: VMIVR-VM-MBX                      Version: 1.0
        License Count: 15/0/0  (Active/In-use/Violation)
License Store: Built-In License Storage
StoreIndex: 0   Feature: securityk9                        Version: 1.0
        License Type: RightToUse
StoreIndex: 2   Feature: datak9                            Version: 1.0
        License Type: EvalRightToUse
        License State: Not in Use, EULA not accepted
        License Priority: None
StoreIndex: 3   Feature: gatekeeper                        Version: 1.0
StoreIndex: 4   Feature: SSL_VPN                           Version: 1.0
        License Count: 0/0  (In-use/Violation)
StoreIndex: 5   Feature: ios-ips-update                    Version: 1.0
StoreIndex: 6   Feature: SNASw                             Version: 1.0
StoreIndex: 7   Feature: cme-srst                          Version: 1.0
        License Count: 100/0  (In-use/Violation)
StoreIndex: 8   Feature: WAAS_Express                      Version: 1.0
StoreIndex: 9   Feature: UCVideo                           Version: 1.0
Did you got the permanent license from licensing team and uploaded to CUE through TFP irrespective of EULA.
Get that one uploaded basis on nos of count VMBX and VMIVR and activate the license of count and reload the CUE.
once done voicemail will enabled.
Br,
Nadeem Ahmed
Hi Nadeem,
yes.i have the permanent license from license team
where to upload the license? upload to cme or to cue?
on the CME show
while on the CUE show
StoreIndex:  0  Feature: VMIVR-VM-MBX                      Version: 1.0
        License State: Active, Not in Use, EULA not accepted
        License Count: 600 / 0
which one to follow?
Angelo
You need to upload this license to CUE using through FTP software tool.
like download software coreftp or filezill (however there n number available on google)
login to CUE CLI
# license install ftp:///path/license_file.lic
# activate the count
# wr and reload
Here are some doc which shall help installing it
https://supportforums.cisco.com/discussion/11908891/install-cue-license-files-ftp-help
https://supportforums.cisco.com/document/32076/cue-licensing-faq#Using_CLI_Commands_to_Install_Licenses
Let me know if this help
Br,
Nadeem Ahmed
hi Nadeem,
I try this command
license install ftp://username:password@ip_address/path/license_file
2911-UnityExpress# license install ftp://admin:cisco@192.168.100.2/FGL9294_98214
but I have error encounter
code 7: reason: Couldn't connect to server
regards,
Angelo
Hi Nadeem
2911-UnityExpress# show license status application
voicemail disabled, no activated mailbox license available
ivr disabled, no activated ivr session license available
2911-UnityExpress# show license all
StoreIndex:  0  Feature: VMIVR-PORT                        Version: 1.0
        License Count: 2 /2
License Store: Evaluation License Storage
StoreIndex:  1  Feature: VMIVR-PORT                        Version: 1.0
        License Count: 60 / 0
StoreIndex:  2  Feature: VMIVR-IVR-SESS                    Version: 1.0
regards,
Angelo
Hi Raj,
Index 0 Feature: VMIVR-VM-MBX
        Period left:  8 weeks  4 days
Index 1 Feature: VMIVR-PORT
        Period left: Life time
        License Count: 2 /2
Index 2 Feature: VMIVR-IVR-SESS
Hi Angelo,
You have not installed the permanent license for mailbox and working on evaluation mode which also is not activated
You still can use the 2 month evaluation which is available.
Run command license activate
license activate voicemail mailboxes # of mailboxes to be activated
You can enter 100 or 600 depending upon capability.
let me know after this and you have to reload the CUE to take license in effect.
Raaj.
Content for Community-Ad
Spotlight Awards 2021
