What is the IOS command to show the analog\pots ports in my VG350?
kbeaton
Beginner
Beginner
I have a third party software I can dig and find this information, but was hoping I could run a command that would show me all the ports in the system and the associated extensions.
These are the two pieces of information I'm looking for, port and extension
AALN/S4/SU0/0@S200-R2-VG350-1.ahs.local - 6699
AALN/S2/SU0/1@S200-R2-VG350-1.ahs.local - 6121
AALN/S2/SU0/2@S200-R2-VG350-1.ahs.local - 4143
AALN/S2/SU0/3@S200-R2-VG350-1.ahs.local - 6106
AALN/S2/SU0/4@S200-R2-VG350-1.ahs.local - 6627
I ran show config, but it didn't seem to include this information.
The reason I say that is because after I ran the command and copy pasted the results into notepad, I searched for 6699 and it couldn't be found...
Thanks in advance for the help!
Kelvin
Maren Mahoney
VIP Advocate VIP Advocate
VIP Advocate
Try:  show dial-peer voice summary
Maren
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
What protocol are you using for those ports?
java
if this helps, please rate
Recognize Your Peers
