08-06-2014 07:08 AM - edited 03-16-2019 11:39 PM
Hi all,
we are currently starting to roll out some video enabled 9900 and 8900 phones in our network. In the past we did not use video and configured the access ports on our Catalyst 2960 switches with "auto qos voip ciscp-phone". This however creates a policy which does not include a class-map to correctly handle the AF41 video traffic coming from those phones. I have thougth about extending the autoqos policy with a AF41 class-map but am not sure if this is the right way to do it.
That's what I have in mind:
class-map match-all AUTOQOS_VIDEO_DATA_CLASS
match ip dscp af41
class-map match-all AUTOQOS_VOIP_DATA_CLASS
match ip dscp ef
class-map match-all AUTOQOS_DEFAULT_CLASS
match access-group name AUTOQOS-ACL-DEFAULT
class-map match-all AUTOQOS_VOIP_SIGNAL_CLASS
match ip dscp cs3
policy-map AUTOQOS-SRND4-CISCOPHONE-POLICY
class AUTOQOS_VOIP_DATA_CLASS
set dscp ef
police 128000 8000 exceed-action policed-dscp-transmit
class AUTOQOS_VIDEO_DATA_CLASS
set dscp af41
police 1500000 8000 exceed-action policed-dscp-transmit
class AUTOQOS_VOIP_SIGNAL_CLASS
set dscp cs3
police 32000 8000 exceed-action policed-dscp-transmit
class AUTOQOS_DEFAULT_CLASS
set dscp default
police 10000000 8000 exceed-action policed-dscp-transmit
How do you guys do it ? Is there some documentation for this ?
Thank you for your kind help
best regards
Andreas
Solved! Go to Solution.
08-06-2014 10:38 PM
Andreas
You can user "sh policy-map X" and "show mls qos" , to check that your class apply or not.
No issues , you only added new class , and add it under policy-map , so no issues. If you need to create new classes which match your configurations , just follow the below:-
class-map match-all Video
match ip dscp af41
class-map match-all Voice
match ip dscp ef
class-map match-all Default
match access-group name Default
class-map match-all Signal
match ip dscp cs3
ip access-list extended Default
permit ip any any
policy-map CISCOPHONE-POLICY
class Voice
set dscp ef
class Video
set dscp af41
class Signal
set dscp cs3
class Default
set dscp default
interface range gig x/x/x -x
mls qos trust cos
mls qos trsust device cisco-phone
service-policy input CISCOPHONE-POLICY
priority-queue out
srr-queue bandwidth share 1 30 35 5
Please rate all useful information
08-06-2014 08:00 AM
You have to keep this table on your mind. Your configuration is fine if your configuration for SD video , but if for HD video , it is not ok you have to change video bandwidth at least 5M.
Traffic Type | Layer 2 CoS | Layer 3 IP Precedence | Layer 3 DSCP |
Voice RTP1 | 5 | 5 | EF |
Voice control | 3 | 3 | AF31 |
Video conference | 4 | 4 | AF41 |
Streaming video (IP/TV) | 1 | 1 | AF13 |
Data | 0-2 | 0-2 | 0-AF23 |
*Interactive Video "AF41"- Sensitive but can tolerate packet loss of about 1% and latency almost same as voice.
*Streaming Video "AF13" - Less sensitive - can tolerate about 4-5% packet loss and latency of about 4-5 seconds.
*HD video conference will require between 5M to 16M , but SD video conference will use 384K to 1 M
Note:-Video QOS , if you will assume that your video conference will use around 384K , you have to add 20% because video conference include voice so the total bandwidth 460K.
Kindly check the below link
http://www.sdcug.com/wp-content/uploads/2011/04/Campus-QoS-for-Voice-and-Video.pdf
please rate all useful information
08-06-2014 10:18 PM
Hello islam.kamal,
thank you for your answer. From what I have read in the documentation for the two IP phone series 8900 and 9900, the maximum video bandwidth will be around 1MBit/s, so to be on the save side I have choosen 1,5MBit/s.
What I am not sure about is if it is advisable to use/modify the auto qos policy for that purpose or if it would be better to create a new custom policy. It would however be more convenient to use the auto qos policy because I could still use the "auto qos voip cisco-phone" command at interface level.
best regards
Andreas
08-06-2014 10:38 PM
Andreas
match ip dscp af41
match ip dscp ef
match ip dscp cs3
permit ip any any
class Voice
set dscp ef
class Video
set dscp af41
class Signal
set dscp cs3
class Default
set dscp default
mls qos trust cos
priority-queue out
